Filling gaps
/ Filling gaps #1
houser52
Gold Member
Cherryville, NC
Kubota M7060HD, Kubota L3600
My dad's tractor loader bucket is worn thin on the bottom rear and is rusted/pitted pretty bad. He picked up two pieces of 1/4" X 6" steel that I welded to the inside of the bottom of the bucket. The scrap yard cut the pieces of steel 1/2" too short and there's a 1/4" gap on both ends from the sides of the bucket.
To fill in those gaps I had thought about laying a piece of 1/4" round rod in the gaps and welding it to the steel plate and to the sides of the bucket. I think that would tie everything together making everything stronger.
Am I going about this the right way?
/ Filling gaps #2
That is called slugging the weld. People do it all the time. ;)
/ Filling gaps
Thanks for the good info and I also learned a new word today, slugging.:thumbsup:
Now I just have to get it finished.
Thanks again
/ Filling gaps #4
We call it the western gap rod up here. Sometimes you take another rod and knock the flux off and use it like a TIG filler rod while burning a rod in the stinger. Maybe that should be called STIG welding?
/ Filling gaps #6
Oooooo. I like the sound of that! :D
/ Filling gaps #8
1/4" gap welding 1/4" plate should be doable without anything extra, unless the bucket sides are real thin or something. If so, I'd just turn the heat down, lay a pass on the bucket side on each side, knock the slag off. You should now be down to ~1/8" gap. Perfect.....weld it up with a second pass
/ Filling gaps
Yeah, I'd looked at doing that but wasn't sure about it. Some places on the bucket are really thin. The more I studied it the better using a rod for filler looked.
/ Filling gaps #10
I've used 7 ga. tension wire for filler when welding some serious gaps on diagonal braces on cantilever gates. Fed it in like tig rod. It's difficult to get a good fit up on those without spending an inordinate amount of time on each one.
1629 (A57192)
1629 (A57192)
2012 BIG TEX PIPE TRAILER (A58214)
2012 BIG TEX PIPE...
KUBOTA RTV900 UTV (A62130)
KUBOTA RTV900 UTV...
Giyi KH72 QA 72" 4-in-1 Bucket (A60463)
Giyi KH72 QA 72"...
1990 INTERNATIONAL 3800 DAY CAB DUMP TRUCK (A58214)
1990 INTERNATIONAL...
240156 (A56859)
240156 (A56859)
