hydraulic oil
/ hydraulic oil #1
catton93
Member
Louisiana
LSXR4040
my dealer is telling me to use john deer 303 hydraulic fluid but my owner manuel calls for API GL4 or ISO/VG 46/68. Can anyone tell me if that in the same as 303
/ hydraulic oil #2
Don't worry about all that API or ISO stuff. Just go grab a pale or two of the universal tractor fluid (UTF) at tractor supply. I won't promote any particular brand because they all satisfy LS requirements. Sam's club also sells it by the 5 gallon pale. Keep in mind that this oil serves the transmission and the hydraulics so UTF will satisfy most compact tractor manufacturer requirements.
/ hydraulic oil #3
Don't use the 303 fluid, it's an old standard for older tractors and not for tractors with wet brakes.
If you use the TSC brand get the "Premium Universal Trans/Hydraulic Fluid" it meets all the specs.
/ hydraulic oil #4
I have yet to do my oil change on the hydraulics but I just bought 3 buckets of Super UDT2 from the local Kubota dealer.
I chose this as a wanted a synthetic and did not want to pay the AMSOIL price.
If the UDT2 does not work as well next time I will switch from the synthetic blend to the full synthetic AMSOIL. Cost was going to be about $100 more if I remember correctly.
From what I have read the hydo whine should reduce and cold weather performance should be better.
I'll let you know how it goes when I change it. About 15-20 hours from now.
/ hydraulic oil #5
Just looked up the AMSOIL, price $162 a 5 gallon shipped
Kubota Super UDT2 was $98 a 5 gallon.
/ hydraulic oil #6
Another vote for the Traveler Premium Universal Trans/Hydraulic Fluid at TSP. Works excellent and last time I checked it was under $40 for a five gallon bucket.
/ hydraulic oil #7
I switched to SUDT2 and a big difference in sound and smoothness of operation. Lot better in the winter too.
As to the OP's question. Pick a fluid that meets the OEM specs. They built the machine and know what it is built to operate with.
/ hydraulic oil #9
Is that a synthetic?
/ hydraulic oil #11
Is there a "reasonably" priced synthetic that meets LS Specs?
/ hydraulic oil #12
If by reasonable you mean under $100 a 5 gallon bucket.. No.
/ hydraulic oil
I found that the Conoco and Shell hydraulic oil list API CL4 on there spec sheets. I have not decided what to use yet. Still looking around. Thanks for the info.
/ hydraulic oil #14
I've been researching if the Kubota meets GL4, and it's hard to determine. In other countries it looks like they list them as meeting GL4. But given that they most likely are manufacture in different facilities / countries I can say that its good to go. One example was the Canadian fluid is made in Canada and labeled differently than the US fluid.
I can't see how it would be any different as both are engineered for Hydrostat and wet brake use.
Here are the mfg specs for both AMSOil and the SUPER UDT2:
View attachment MSDS KUBOTA SUPER UDT2.pdf
View attachment Amsoil MSDS HydraulicTrans.pdf
On another note Ashland = Valvoline
/ hydraulic oil
I have found out that Ls does have a hydro fluid and my dealer is checking on getting some. I found a dealer that has it but they are 3 hours away.
/ hydraulic oil #16
Speaking of hydraulic fluid? If anyone with experience can tell me if replacing the hydraulic fluid with synthetic will give me a smoother operation of the loader and backhoe when the fluid gets hot? As it stands right now, when the hydraulic fluid gets hot the controls operating the loader and backhoe are super touchy. I know synthetic is more expensive, but my little XJ2025 HST only takes 5.3 Gallons per the owners manual. So, if I can get better operation. It may well be worth the extra cost.
Any help or suggestions would be much appreciated!
Thanks,
Silverstreek
/ hydraulic oil #17
Thanks,
Silverstreek
I asked same a few posts back and never really got much response. I will check with my dealer and post back here. I'm at 190 hours so, need to decide on a plan for 200 hour maintenance.
/ hydraulic oil #18
I certainly appreciate it! I'll keep an eye out for your reply.
Thanks again!
1062 (A63291)
1062 (A63291)
2014 Kia Sorento SUV (A61574)
2014 Kia Sorento...
14in Digging Tooth Bucket Excavator Attachment (A64194)
14in Digging Tooth...
(10) Free Standing 24' Cow Panels w/1 Gate (A64119)
(10) Free Standing...
2017 Ford Expedition SUV (A61574)
2017 Ford...
UNUSED ATS POWER ATS-PC90 HEAVY DUTY PLATE COMPACT (A64281)
UNUSED ATS POWER...
