Ammunition
   / Ammunition #331
So, I was wondering if any of you have found an SKS scope or red dot set up you like. My Norinco came with the receiver cover type, that fits pretty darn loose, and also blocks iron sights. I am thinking of going to an AK style side mount. The rail itself is cheap, and I know I'll have to drill and tap the reciever. I would love if it also solved the shells ejecting into scope problem. Pretty much everything I'm seeing is AK side rail, then side mount with 1913 rail on top, then rings, then scope; and my concern is I don't want it being 6" taller than my rifle. Ideally, I would want something like the scope mount in SVD. Any thoughts? Also, I'm cheap, so putting $300 scope and rail on SKS just ain't gonna happen.
Edit: I'm Not looking to put flashlights, laser sights, pistol grips, battery powered chainsaw baynets, or anything else to go tactiCOOL
Have a set of TechSights on my SKS. Money well spent.
   / Ammunition #332
agreed. it will fire a slug with full choke.. but might take the tube with it right out the end of the bbl.
A Forster (Foster) slug won't damage a screw-in choke, but the Brenneke slug is a little less flexible. The Forster slug is the most popular.
Sabot slugs should never be used in a choked barrel, though there are rifled screw-in cylinder chokes available that will do a moderate job of stabilizing a sabot. Rifled chokes will foul pretty quickly shooting smooth bore slugs.
   / Ammunition #333
I'd still never fire a slug thru a screwed in 'full'
   / Ammunition #335
me neither, especially not after watching this:
Remember, some have to pee on the electric fence to learn :)
   / Ammunition #336
Now I'm up to speed, that was a good demonstration on slugs going through different size chokes, just shows me that the popular choice here was right one, I.C. choke and that's what I'll look for. So far the gen. price is around $25.00 for the Mossberg brand, but I'm giving the S.S. Carlson brand a look see, it's a little cheaper with good reviews.
   / Ammunition #337
"Brandon (Kirsties husband) shooting some slugs at 200 yrds"
For some reason banging a steel plate doesn't have the same ring as punching holes through 1-1/2" counter top, good shot tho. I liked what Hickok45 said, when something like that is thrown away it always goes by the range first, same here at my range.
When I get slugs for my 20 ga. I'll setup a 2" thick plank at 400 yards and put some holes through it, on video of coarse. :thumbsup:
   / Ammunition #338
We are waiting on the video... Man if you can do it more power to you. 75 to 100 yards is all I have ever shot them.. BUT I was pleasantly surprised how well I could hit at that distance. We can rarely see a deer much further around here in the brush anyway. But if you don't have a fancy rifle, and the ranges are not too long, you CAN put meat on the table with a scattergun if you try. I seriously doubt I would shoot at a game animal with a foster slug much over 100 yards, but I believe they are a good choice for close range deer getting.
   / Ammunition #339
Brush here is much the same way. My 30-06 is sighted to 100
My last hog was 75 yes.
I could have taken many at 50.
I think even my 69 caliber smoothbore would have taken them :)
   / Ammunition #340
My new 20 ga choke tube wrench
Estimated hours of job completion was 8 hours, but was completed in 3 hours under budget and ahead of schedule. The wrench was made out of old reciprocating saw. I started at the end of the blade that goes into the saw and started grinding from there. A little bit of grinding on both sides and then when done, welded a chain like handle on the end. Another one of my ingenious designs. The moral of the story is I saved $10.
IMG_0496 by Mark Rhodes, on Flickr
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2015 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2015 Ford F-250...
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
2020 Mesa Ridge 32ft Lite Travel Trailer (A49461)
2020 Mesa Ridge...
Marliss Industries Grain and Soybean Drill - Selling ABSOLUTE NO RESERVE (A51039)
Marliss Industries...
2020 INTERNATIONAL LT625 SLEEPER (A50854)
2020 INTERNATIONAL...
