   / Harbor Freight Tools that don't suck #5,531
IMHO if you were going to do HD production with large pieces or high volume, the HF Bandsaw probably would not be your first choice. I used to use a chop saw or hack saw then discovered the portable band saw. Looked at many from $ to $$$ and ended up with the HF portable band for way under $100. It has done well for me but, sometimes you need better than handheld accuracy. I have a side project to build a stand to hold the HF portable BS in vertical position and ordered a $60 table kit for it from Swag Off-road.
SWAG V1.0 Portaband Table
I might find out that this project meets all my needs and will no longer need to consider the HF 4" x 6" BS. That ...... Would be GREAT!
   / Harbor Freight Tools that don't suck #5,532
For what it's worth, regarding the stand, I weigh about 220 and frequently use the saw for a step ladder to get to a lumber storage rack hanging from my garage ceiling. Its solid as a rock.
You have guts.... I use a stepladder.
   / Harbor Freight Tools that don't suck #5,533
I have the HF portable bandsaw. It works great but 'some assembly required' understated the case.
I had to shim the foot putting a nut under one edge, to get its notch parallel to the blade so I could estimate where it was going to cut.The guide roller screws were loose and soon fell out. After completing what should have been final quality control at the factory it's a good tool.
   / Harbor Freight Tools that don't suck #5,537
I fell off a stepladder a few months ago. I've never fallen off my band saw. :laughing:
Said similar about a horse I had about 20 years ago.
   / Harbor Freight Tools that don't suck #5,538
An ice dam took down part of our gutter. That pulled the soffit open on the north side of the house. A bird went in, and managed to go up and over two peaks to the west/south corner of the soffit and was flapping around in there for 2 days, right outside our bedroom window. It couldn't find its way out. So, I had to use a 6' step ladder to open up the end of the soffit, then go and pound on the soffit with a broom handle upstream of the bird to chase it down to the now open end. Just as the bird poked its beak out of the opening, the opening snapped shut. So I asked my wife to stand next to the ladder while I climbed up to re-open the soffit end. She did exactly as I asked... she stood next to the ladder. I didn't ask her to hold it. :laughing: As I went up 3-4 steps the ladder pretty much jumped out from under me. It went left, I went right, the back of my head hit the house, my back landed on the ground, and my butt landed on the ladder. I laid there for about a minute expecting something to start hurting.... nope. Just my pride. I was sore the next day, though. :rolleyes:
   / Harbor Freight Tools that don't suck #5,539
And I think its a Sears ladder, but that's for another thread. :D
   / Harbor Freight Tools that don't suck #5,540
Can you please post the video?
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
SINGLE STAGE AIR COMPRESSOR (A52708)
SINGLE STAGE AIR...
2014 Sakai SV540T Pad Roller, Chassis# 3SV53-10137, PMC Power Motive, Cummins Turbo Diesel Engine, (A59076)
2014 Sakai SV540T...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2017 Ford F-150...
2012 International Prostar (A56435)
2012 International...
2012 Vantage P-42-1000 42ft. T/A Dry Bulk Pneumatic Tank Trailer (A55973)
2012 Vantage...
