Kubota B7610 hydro issues
/ Kubota B7610 hydro issues #1
Hooked_on_HP
Coal City IL
Ford 1900 FWD Kubota F2100E
I have a b7610hst with around 1000 hrs on it. I started to back it out of the garage and it started moving then it paused for a couple of seconds then it started moving again . Now is where things got bad. It stopped moving again and started making a loud squelling noise out of the bell housing. If I push the clutch in the noise goes away. I checked and the shaft that goes from the bell housing to the main hydro pump is not spinning. It just chatters. It is full of fluid and I did try replacing the hyd filters. I am hoping it is something simple like a striped clutch shaft. My service manual doesn't give a good pic of what is in the case that bolts to the bell housing. One pic shows 3 shafts and gears and another shows like the outline of a pump. Any one had one of these apart. I am in the process of splitting the tractor now.
Bill
I got the tractor split apart and found the problem. The splines on the clutch disc are totally gone. All thing considered tis is the best I could hope for. I don't under stand why it happened. The clutch shaft looks fine. When I was taking it apart I noticed it had been apart before. I don't know if the clutch had gone out before and some one put a cheep one in it or what.
Here is my next dilemma . This clutch disc has no springs or rubber to cushion the clutch. This is an original Kubota disc. There are aftermarket discs with springs. I am wondering if springs my prevent this from happening again
/ Kubota B7610 hydro issues #4
Having springs on the clutch disk will definitely help preventing the clutch disk breaking down, but the above issue you have got may not only depends on the springs.
(10) 6 Bar 20' Continuous Fence Panels (A66408)
(10) 6 Bar 20'...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
JMR TREE BOOM (A61572)
Heavy Duty Fork Extensions (A65640)
Heavy Duty Fork...
New/Unused 20ft Metal Farm Driveway Gate (A65583)
New/Unused 20ft...
1993 GMC Sierra Pickup Truck, VIN # 2GTEK19K7P1534489 (A65563)
1993 GMC Sierra...
