1993 Ford 3930 clutch question
   / 1993 Ford 3930 clutch question #1
LondonDave
Melbourne, Ontario Canada
John Deere 5410 MFWD, Case IH 5230 MFWD
The clutch on my 93 Ford 3930 is to the point where the pedal is almost all the way to the top before it engages. It doesn't seem like it's slipping but I haven't really tried pulling anything that would cause it to. What I have noticed is when I'm starting out in reverse high range it seems to struggle a little and almost stall the engine. Is my clutch shot or almost shot or is there any adjustments that can be made?
Thanks
Dave
   / 1993 Ford 3930 clutch question #2
Thanks
Dave
Does your 3930 have a loader?
How many total hours on the tractor?
   / 1993 Ford 3930 clutch question #3
Dave,
Clarify a couple things. The clutch pedal has the proper amount of freeplay?? If so, then your clutch is about gone. If not, adjust the pdeal freeplay and then tell us how the pedal feels in regards to where it engages the clutch.
Dave,
I believe the free play is adjusted to it's max. I need it to engage sooner when it comes off the floor board and I can't adjust it to make that happen.
   / 1993 Ford 3930 clutch question #6
Free play adjusted to the max. Are you saying there is no more adjustment on the linkage to gain freeplay?? Are you saying you have no freeplay at the pedal???
I'd have to look at it again. I think I have too much free play. Instead of the clutch engaging 1.5-2" off the floor board it's not engaging until all the way to the top. I could add more free play which I don't want but I can't adjust it to have less....if that makes sense. I can't turn the linkage out anymore to take free play away but I could tighten it in which would give me more free play....I think. Maybe I've got it all wrong.
   / 1993 Ford 3930 clutch question #10
You have a new clutch in your future.
Out of curiosity, I wonder if at 3500 hours that is the original clutch?
On a tractor with a loader, I would think not possible.
2015 FORD F750 26FT BOX TRUCK (A51219)
2015 FORD F750...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
2014 Chevrolet Tahoe SUV (A50324)
2014 Chevrolet...
2014 FREIGHTLINER M2 REAR LOADER GARBAGE TRUCK (A51219)
2014 FREIGHTLINER...
Pickup Instructions (A47384)
Pickup...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
