How much tractor do you need?
/ How much tractor do you need? #1
MutzFarm
Gold Member
Texas
Kubota M62
Well I aint saying Im the smartest, but how much tractor do you need? Took my 2012 Mahindra 4wd 4025 with a 6ft shredder thru some brush that at times was 8ft tall.
/ How much tractor do you need? #2
I did that one time with my 1710 and a 5 ft. I t was kind of strange driving over little trees that were taller than I was and just having it chew them up. That sounded like a nice load for that tractor.
Yes sir. The homemade canopy on there is 8ft from highest point to the ground and some of that stuff was up there.
/ How much tractor do you need? #4
If you listen to some guys you'd have a 4 foot cutter on that thing. Until you are stalling out in first gear you aren't out of power. A HST is only limited by cutter weight.
/ How much tractor do you need? #5
/ How much tractor do you need? #6
I'm completely convinced I need way more than I'll ever own. :D
/ How much tractor do you need? #8
I like these things.
I had two of them clean my way overgrown five acres up in two days flat.
It is an old dale philips 6ft shredder on there. This unit is gear driven not HST.
Im in TEXAS where everything is bigger and a am a full red blooded TEXAN that will always believe more power and bigger is always better! ;)
I never saw anything like this before. I hope the link works.
Texas Brush - YouTube
Its as if he is bulldozing thru the brush with the tractor and that aerator looking job he is dragging is just heavy enough to cut through the majority of that brush.
Those are nice, but I would only have one if it was a closed cab. Could you imagine a open cab doing that?
/ How much tractor do you need? #17
impressive. What kind of mower?
It's an old Rhino TW72. I gave $1,000 for it, put about $300 into repairs and have abused the heck out of it. It's got some rust coming through the deck that I need to repair but, it's taken everything I've thrown at it and kept on trucking.
/ How much tractor do you need? #19
doesn't that tear up the bottom of the tractor, hoses and such?
I haven't had any issues with that, it's all protected pretty well underneath, sort of like NH thought a tractor might get used in rough terrain and brush :) . Mashing it down with the FEL first helps some also.
I usually back into really heavy stuff now. I've done more damage backing in than just driving over it though. Bent a stabilizer bar, killed some tail wheels, etc.
/ How much tractor do you need? #20
Nope. In fact when they started on my place it was dry so they had to stop for a few days until some rain fell and settled got the dust down. The cab seals in one of the track loaders, the older one, weren't so great and the operator could hardly breath. The owner said the county would give him a dust ticket if he'd kept it up. It was either wait for some rain or use water trucks and haul a lot of water in and that of course adds to cost.
1984 Cab Over K100 Big Cam 350 (A62613)
1984 Cab Over K100...
Freightliner Columbia (A63689)
Freightliner...
Grease Pneumatic Air Gun, 50' Hose  (A62679)
Grease Pneumatic...
Camco Running Gear (A66408)
Camco Running Gear...
2019 Kubota SVL95-2S (A64126)
2019 Kubota...
2016 Volkswagen Jetta Sedan (A61569)
2016 Volkswagen...
