looking to get a Kubota or JD
/ looking to get a Kubota or JD #22
I personally prefer the standard transmission over the HST , especially if you are working steep ground and have much 4wd activity. Just better control in my view.
This is the part of your post I have trouble with. In my view just the opposite is true. I live on very steep ground and have operated both straight gear and Hydrostatic machines here in Branson where a 2WD tractor would be useless, and the Hydrostatic machines give you much better control and safety than the gear machines.
I think some people base their usage of a hydrostatic tractor on how hydro lawn mowers operate, where they will roll off immediately down hill if you let off of the hydro pedal, and barely have enough power to climb some steep hills. But operation of a full size hydro tractor is nothing like that.
I have seen several poster say that gears are better for hilly ground, and I just ain't buying it. I have extensive operation of both in hilly terrains, and it just does not fit with my experiences.:confused3: What say others?
/ looking to get a Kubota or JD #23
Mine too, we have several tractors and the tractors I use the most are L5740HSTC and M8540HDC, I formerly used a Case CX80 and Massey Ferguson 375 on the same farms, all FWA-MFWD etc., we tried 2WD and quit.
/ looking to get a Kubota or JD #24
This is a personal preference item -- HST versus gears. To each his own. The HST has the potential for being in the wrong range and, with good traction, sitting there humming rather than turning the wheels. The HST takes a % of the power away from whatever you started out with. Clutches are cheaper than HST drive units. You can coast a std transmission to start it if need be. Etc. I do mostly 4wd work on often steep ground with a 7ft bush hog. I prefer a std transmission.
/ looking to get a Kubota or JD #25
And you have the potential to be in the wrong gear on geared machines and stalling out; neither is likely with an experienced operator.
/ looking to get a Kubota or JD #27
We do a lot of work on steep terrain also - when my buddy is working his land and on the ultra steep part he always asks me to bring my HST down and mow it with my 6' brush hog because I have some much more control than he has on a gear machine. He has been farming the land for 40 years and always says how much slower and safer my tractor is on the hill and even in the deep woods due to the tranny....
/ looking to get a Kubota or JD #28
Either tractor will do the job, it's all in what you want, I like the HST better than the gear model, but that's just me.
The Kubota's and the Deere are both great tractors.
/ looking to get a Kubota or JD #29
And if you *are* in the wrong gear and need to clutch it...well, now you better hope your brakes are good. With my HST, I can come to a full stop and even start to back up the hill, all under full power and control. In addition, I've seen a gear tractor stall out and at the moment of the stall, start running backwards, sucking in air from the exhaust. Granted that was under load from digging, not a hill, but I can imagine that wouldn't be a good time on a hill.
/ looking to get a Kubota or JD #30
Wow, I guess it's a good thing an HST is available for those that can't operate geared equipment.
/ looking to get a Kubota or JD #31
Yeah, we have a couple of tractors like that and only use them on our flat land farm, other than pi** poor brakes, they are really good old tractors. We have really good brakes on our M8540 fortunately as we often have to change directions on some pretty steep slopes.
I had an old two-stroke dirt bike that would stall out and start running backward if pushed to hard, really scary on a slope; usually bucked me off.
/ looking to get a Kubota or JD #32
You said it. I'd go with either HST or one of our geared tractors on a hillside; about the only transmission I wouldn't want would be any of the powershift types. If Kubota makes a powershift I don't know about it, but JD sure used that tranny a lot. I've got one of those now....and have had others, plus our land is about as rugged as usable land ever gets.
But what would really make up my mind more than the transmission for hillside work is brakes, side-hill stability, traction, and then brakes again and again and over again!.
Our old (and newish) farm tractors are sure wonderful machines and I'll bet they are still going strong, but none of them had brakes to compare with the brakes that are common on our TLB tractors.
Say, are you going to look at New Holland and others? Or is it just JD and Kubota?
luck, rScotty
/ looking to get a Kubota or JD #33
luck, rScotty
I hope I'm done buying tractors as we just use SCUT, CUT and UT now, never used any of the big Ag tractors used now. The predominant tractors in my area are 8000-9000 John Deeres, standard and a few articulated, one uses all tracked JD machines. I do like the New Hollands, but the last time I looked at them, my wife "suggested" I just keep driving. :) A neighbor just got one of these:
/ looking to get a Kubota or JD #34
Too many steps to get into the cab there TripleR!:D
/ looking to get a Kubota or JD #35
Ain't that the truth, I have enough trouble getting into our M8540, I'd have to stop and take a break climbing into that tractor.
My brother has been transporting and mixing chemicals for one of those tall John Deere spray rigs, talk about a climb, I'd need steps to get to the steps.:laughing:
/ looking to get a Kubota or JD #37
I guess you have never stalled a gear tractor.
/ looking to get a Kubota or JD #38
luck, rScotty
I am one who prefers the stick shift. I used a JD4700 for 10 years on very steep ground at times with a 6ft bush hog and never had ANY problem with using the stick shift, the "power reverser" as Deere calls the power shuttle, or the brakes. YES, all the major manufacturers sell power shuttle transmissions to the point where it is the defacto standard now. Deere was years ahead of the others on that in the utility tractors soon followed by New Holland, Kubota and Massey. But it took almost a decade for the whole industry to come out with the power shuttle. I agree on the brakes !! My MF 2660 had the "4 disc" version of their brakes which will not stop the wheels from turning on a 40% slope -- suicide. MF eventually installed a "5 disc" set of brakes for me and it is fine now. No matter the transmission you darn well better have brakes.
/ looking to get a Kubota or JD #39
We have a HST Kubota that's great for loader work (bought used). Problem is that Kubota uses a rocker pedal and my right knee feels the back-and-forth twisting action the next night and day.
A neighbor has a Massey that features separate pedals and it's built a lot heavier and the cab is spacious. ( heavier is better). The Kubota's been reliable and great value , but I'd still shop MF if at all close to your location and if the dealer is deemed reputable.
One final note - ensure that the rear wheels are set far enough out to accommodate chains.
/ looking to get a Kubota or JD #40
Let me give an example of HST efficiency. There's a lot loads of poop spread here on the farm as the cattle are fed on a concrete feedlot. Either of the HST's here can heap load a 155 bushel manure spreader in under 4 minutes. The old gear drive IH 574 which had a mechanical shuttle for forward and reverse took close 10 but some of that was because it was 2WD. When they bought the HST no one knew exactly what to expect but it has far and away been one of the best decisions made here as far as equipment purchases. Now if you're talking doing flat out field work, they like nothing better than the gear drive and the powershift of the 5140.
As far as being in the wrong range, you can shift from range to range just as fast or not faster than you shift a gear drive.
2008 CHEVROLET EXPRESS VAN (A60736)
2008 CHEVROLET...
MTL Forks (A60463)
MTL Forks (A60463)
2012 DIAMOND T TRAILER TRAILER (A58214)
2012 DIAMOND T...
2860 (A56857)
2860 (A56857)
Giyi SE61 QA Broom Sweeper (A60463)
Giyi SE61 QA Broom...
CFG Industrial MX15RX (A60463)
CFG Industrial...
