I need an AR-15
   / I need an AR-15 #201
AR5 and AR7 were USAF Air crew survival rifles. One shot 22 Hornet rounds and other used 22 LR.
U talking about the M6 survival? I got a Springfield M6 with 22 hornet top barrel, 410 bottom. Folds in half with spare rounds in the but stock.
   / I need an AR-15 #205
MIL-SPEC is simply a short version of MILITARY SPECIFICATION. It has nothing to do with the process of milling. My company manufactures MIL-SPEC hydraulic hose for which a milling machine is not necessary.
Sent from my iPhone 2.0 using TractorByNet
   / I need an AR-15 #207
I wouldn't trade either of my present AR15's for 20 copies of the M16's (my original was still labeled an AR15) that I carried around for 3+ years in USAF in late 1960's.
When I first joined the "Be All You Can Be" Army, my M16 said "AR15" on the side. God bless that A2. :)
   / I need an AR-15 #208
Exactly. There are mil spec computers and phones etc. I assume there are mil specs for K rations too. Nothing to do with milling of metal.
   / I need an AR-15 #209
Davy Crockett most likely used a military spec musket, to kill his food ..
   / I need an AR-15 #210
I don't know if you guys have ever actually worked with MIL-SPECS, but they aren't any more stringent then most commercial specs. In fact, many MIL-SPECS has been superseded by commercial specs.
As far as "Every part is milled to a specific spec", all machined parts are milled to a specification (called tolerances). MIL-SPECS aren't necessarily a tighter spec as tighter specs can lead to less reliability.
Colt manufactured to a mil-spec in some components since those components were shared with the firearms sold to the military.
I was in the military for about a decade...worked in more then one DoD supplier (mostly QA in machine shops). MIL-SPECS aren't some holy grail...they're just specs.
Now, when NASA was involved, different story..and after the USS Thresher incident (in 1962), zero defects in submarine building meant zero-defects....but all in all, MIL-SPECS weren't really that stringent.
But, use of the term "MIL-SPEC" in advertising sure sold some Colt AR-15 rifles!
Yes my company is a defense supplier and we work with specs routinely. They can be vague or very detailed and precise. All depends on the application. Heck... toilet paper is available per MIL-SPEC P43988.
2019 CATERPILLAR D6 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2017 Nissan Titan SV Crew Cab Pickup Truck (A50323)
2017 Nissan Titan...
2010 CATERPILLAR CM1210106 ROUGHT TERRAIN FORKLIFT (A51242)
2010 CATERPILLAR...
2007 INTERNATIONAL MA025 DAY CAB (A51219)
2007 INTERNATIONAL...
(5) Rolls of Barb Wire (A50515)
(5) Rolls of Barb...
5' X 20' 3/8" THICK STEEL PLATE (3) PIECES (A51244)
5' X 20' 3/8"...
