How to keep a tractor from getting stolen?
   / How to keep a tractor from getting stolen? #111
I like the idea of getting a 20' steel shipping container for long term unattended storage. I suspect a solid lock would make one of those a vault
Would storing a tractor with its onboard diesel fuel in a hot container for a month at a time be a problem? I've stepped into one of those and found it to be an oven during even our summer months. I would think taking the battery and keeping it near on a trickle charger would be a useful for battery life and a bit more security.
That works fine.
I've had a 40' for about 7 years on my remote property and have stored an 8n tractor filled with gas and two four wheelers and gas cans all full through GA summers with temps inside the container probably reaching 140+ on the sunny side of the wall. Probably dangerous but it's worked all these years and no issues yet even with an electric golf car and battery chargers running. The container is wired up to electric service as well. I don't leave lights on inside, though, but I do turn on the lights when I arrive sometimes after weeks or months at a time.
Gas fumes tend to sink meaning anything not gas proof should be elevated including electrical stuff, just like in a garage. My snake boots have melted soles and degraded interior from just that. I learned my lesson.
My new Kioti tractor should fit but for now I have to find a place for my 8n and the bushhog and box blade and all the other junk. Those containers are 9ft high so it should fit easily.
I just use a shoulder jacketed armored padlock that can be cut but like the other posters said you will run out of 18v grinder battery before you cut through that much steel and if you cut the handles for the door releases you wouldn't be able to open the doors anyways.
Nobody can stop a pro thief. A rollback will easily pull a 6000 lb tractor up the back with it's probably 12k+ winch. Even with wheels turned a sheet of plywood would make a great sled for turned wheels. The rollback is what delivered the container to the property in fact. They are purpose built for doing what we are talking about - stealing equipment.
But you are not protecting against them. You're fighting the meth heads and the **** kids that think they should play with your equipment like we all did when we were kids. And usually, a heavy chain will protect just about anything but parts thieves will dismantle whatever they want. Hex chain is near impossible to cut with any cutter besides cutoff wheels because of the flat sides making the psi required exponentially higher.
So, the containers are the best. I live near the ports so containers are 1000 bucks and delivery is maybe 200 if that. I might buy another one since they are perfect garages, sheds, etc. They have heavy thick wooden floors are actually are vented but barely. Those vent holes make good wasp nests. Mine's painted forest green so it doesn't stick out. You could easily camo it and you wouldn't see it from 100 yards away if you didn't know it was there.
   / How to keep a tractor from getting stolen? #112
I know this is a old thread but I cant figure out how to implement my idea to a diesel tractor . My dad would run a wire from the coil to a ground on the chassis with a round male/female plug so when it was plugged together the coil couldn't function . You had to unplug the wire to make it start, so thief's would see wires connected and be fooled as to why there was no spark . How could I try this method on a diesel ? . I am very limited on my imagination and I think I am trying to kill the fuel supply but I cant quit figure it out .
   / How to keep a tractor from getting stolen? #113
You could always disconnect one wire from the seat switch or any safety circuit. (or add a switch in line)
Maybe even 2 safety switches just to be sure.
(mine is to simply unplug one wire on the switch)
While a knowledgeable thief might guess what you did he'd have to find out where you broke that circuit.
On light aircraft (Cessnas etc) we often did the magneto short to ground switch trick and label the switch something like 'turbo boost' or 'ejector' to fool thieves.
   / How to keep a tractor from getting stolen? #114
I disconnect a safety switch in a place no thief would ever guess unless they knew a lot about the Kubota B21. (I remove a plug in jumper that looks like a test port.) I also leave pto engaged. Only tractor people would think to check that. To prevent tow trucks I always leave it with the backhoe on, and extended sideways. And blocking in the dump trailer at the same time.
   / How to keep a tractor from getting stolen? #116
Just insure it. Problem solved.
For us Kubota Owners; I doubt you can beat the price for KTAC insurance. I kept mine after paying off the BX. Last year KTAC paid off on an $8K damage claim on my BX; figure I cannot afford to be W/O it considering how and where I put mine to use. I also have a valve in the fuel line way back underneath ahead of the first filter. I close that and run out the fuel when ever I park the BX at the church overnight. Also makes filter changing easier.
Ron
   / How to keep a tractor from getting stolen? #118
Or place in a throttle spring. When you are away from the tractor, the throttle level feels like it should, yet it's not connected to anything. They can pull and set the throttle all they like, but the engine will not fire up. haha This should work on many of the tractors pre-90's.
   / How to keep a tractor from getting stolen? #119
How does insurance keep tractor from being stolen which is the topic of the thread.
If it's insured and lifted you get compensated, what insurance is for. I guess with a little tractor you could use a pickup and small trailer to lift it. With mine, it takes a semi trailer. with ramps or a winch. Not gonna happen.
   / How to keep a tractor from getting stolen? #120
I rarely think about such things as getting equipment stolen. One. it's all insured and two, I have lots of firearms and I'm a helluva shot.
2000 CATERPILLAR 322BL EXCAVATOR (A52707)
2000 CATERPILLAR...
1988 Kenworth W900B Dump Truck with 3406B CAT (A57024)
1988 Kenworth...
Kubota LA1055 (A53314)
Chevrolet Metal Tailgate Art (A55853)
Chevrolet Metal...
2017 Ford F-650 Stakebody Flatbed Truck (A53422)
2017 Ford F-650...
