Hose protector
/ Hose protector #1
Kodiak45
Gold Member
SC
long 2460 - belarus 250 - JD 4230 - Kioti DK40SE
Anybody have any loader hose protector fabrication to share. I hate seeing those hoses and fittings so exposed. My father in law knocked one off one day and I've been determined to make some protector ever since. Any ideas uploadfromtaptalk1456888524422.jpg
/ Hose protector #2
There appears to be a steel bracket above the hoses. It shouldn't be hard to build a box around them.
/ Hose protector #4
At that location on my Kubota there is a skid plate under all the hoses/connections with an upturned portion on the front that extends up about 6-8 inches. Its probably there to do exactly what you are talking about.
/ Hose protector #6
i made this little skid plate for my CK35 and protect good so far even in wood
/ Hose protector #7
Nice looking skid plate. Are you able to mount and remove the backhoe with this plate installed?
I am very interested, could you possibly take some more pics showing how you attached this plate.
/ Hose protector
X 2. That skid plate looks very nice. More pics would be greatly appreciated
/ Hose protector #9
Not only does that skid plate look very nice .... that looks to be one clean tractor!
/ Hose protector #10
What is the extra wrapping on the hose?
BarnieTrk
/ Hose protector #12
Yep, that is what I was talking about.
"Techflex Flexo Wrap FR Hook & Loop Braided Sleeving"
Thanks for the link, Dragoneggs!
BarnieTrk :thumbsup:
/ Hose protector #14
i have more picture and some for the other side work real good attach to transmission with metric bolts
/ Hose protector #15
Anybody have any loader hose protector fabrication to share. I hate seeing those hoses and fittings so exposed. My father in law knocked one off one day and I've been determined to make some protector ever since. Any ideasView attachment 459165
Among the many things I fabbed up for my Kioti NX series was a loader hose loom and guard.
/ Hose protector #16
I have used short (3 to 4 inch long) sections of old radiator hose in the past. I slit it along its length, slip it over the hose where it may see rubbing or wear then zip tie it tight to the hydraulic hose to keep it in place. Not real pretty - but very functional.....
BarnieTrk
/ Hose protector
I like the idea of a protector over the hose, but my main concern is protecting the couplers. A stick knocked one of the couplers once and disconnected it and it has dripped a little ever since. I've disconnected and tried to clean the connections out a few times with no success, so when I finally get that leak fixed one day I'd rather keep it from happening again.
/ Hose protector
I'll replace a busted hose any day, but a bent manifold and coupler would be a pain I the butt, not to mention very expensive
/ Hose protector #19
Don't those couplers have one or two O-rings inside?
Maybe one or both of those O-rings were damaged and warrant being replaced to stop the leakage?
BarnieTrk
Trailmobile Van Trailer (A63118)
Trailmobile Van...
High-End Mini Golf Cart (A62183)
High-End Mini Golf...
Knuckle Boom Crane (A62183)
Knuckle Boom Crane...
2010 Ford Crown Victoria (A61574)
2010 Ford Crown...
2018 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2018 KENWORTH T680...
John Deere 2500A Reel Mower (A62183)
John Deere 2500A...
