Stopping leak down
/ Stopping leak down #1
farm23
Western, NC
PT-1430, Wright Z-turn mower, BCS 853
I need to stop the bucket from leaking down [1430] and am thinking of installing a valve in the top hydraulic lines from the cylinders. Two questions.
1] Will this work and if so does anyone have a suggestion on the valve?
2] Is there a better solution?
Thanks;
/ Stopping leak down #2
When you buy the boom mower, they install needle valves (one for each of the cylinders) to lock the arms in place. Close them to lock and open to allow movement. Ball valves would work as well if you only want full on or off.
Ken
JJ my first thought was I would need one to provide flow in one direction but I think under normal operations I would need flow control in both directions. So as usual I have confused myself.
/ Stopping leak down #5
Thanks;
Double piloted check valve.
(96) BOARDS OF 1"x8"x8" PONDEROSA PINE (A65055)
(96) BOARDS OF...
SHOPBUILT S/A TRAILER (A64278)
SHOPBUILT S/A...
APPROX (50) UNUSED 3'x8' CORRUGATED METAL SHEETS (A65055)
APPROX (50) UNUSED...
Texaco Gas Pump Yard Art (A64557)
Texaco Gas Pump...
2008 Ford F-350 4x4 Crew Cab Emergency Service Truck (A64556)
2008 Ford F-350...
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
