Good morning!!!!
   / Good morning!!!! #43,901
Good morning,
Cooler and cloudy with rain tonight. 42 now heading to 60 later. Spring weather for sure. The underbrush is turning green and that means the end of the line for free food for the deer. When this bag is gone there on their own.
buckeyefarmer, Happy birthday to your dad!!
   / Good morning!!!! #43,902
Too bad you're not a bit closer, RS. There are at least two pet carriers in the basement here, and they'd be yours for the asking...
Yeah ... it's a bit of a hike ... bummer.
But thanks for the thought :D
   / Good morning!!!! #43,903
I changed out the pto switch on Bernice's JD Z 910A and still the blade clutch does not engage. All the wires look good, all the safety switches work properly. The only thing left is taking the clutch off and that would require . . . . I told her she would have to take it in. Sorry.
Don,
I would look at the wires going to the clutch, I have seen where they get cut through by the belts sometimes.
   / Good morning!!!! #43,904
Those clutches do go bad, they work like an ac clutch and I've replaced many of them. Some more elaborate electromagnetic clutches have adjustments, others can be tweaked by tapping with a hammer. But usually you just replace it.
   / Good morning!!!! #43,906
That was one machine I cannot get under to change it out.
   / Good morning!!!! #43,907
66°F and .23 inches rain last 24 hours.
Nothing too strenuous planned for the day.
Be safe
Have a great day
David Sent from my iPad Air using TractorByNet
   / Good morning!!!! #43,908
Happy 92nd birthday Dad.<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=462012"/>
Happy 92nd
Well done :)
   / Good morning!!!! #43,909
Steel and spray paint moved up to shed, enough of the welding table cleared off (better than half) and cleaned to work, a little clean up started in the shop.
Time to grab a shower and then start the cat round up.
   / Good morning!!!! #43,910
buckeye,
Happy Birthday to your Dad.
   / Good morning!!!! #43,913
I can surely attest that unless one is young and spry like Ron that driving ten hours in an rv in heavy traffic
will leave one wilted. And with a headache. But that's all. Trailer pulled great, and despite it basically dwarfing the truck, that hemi rocked and had zero
problem keeping up with traffic and the 8 speed trans on tow/haul just rowed the tunes out.
A good thing the truck takes regular gas, which I paid 1.76 or thereabout several times today, though I filled up at least three times.
Slurp. 9mpg. And I was doing all of 64-65 max in the right lane in a 70mph zone. Frankly there was so much traffic no one was getting anywhere any faster than I was as several times I had to come off cruise and slow down as the traffic just clogged up.
I bet I could have got 11mpg if I hadn't used cruise. Come hill or dale the trans downshifted and upshifted smoothly
and since I never saw over 2900 rpm on cruise, I just let it do its thing.
Like my own little symphony of baritones...that engine has chops.
the trailer bed is hard as a rock, shortly to get some kind of pillow top. And all night long heavy trucks went by about 50 feet away. Let's say the ambience was lacking but otherwise it all went well. Everything worked.
I feel like I've been on a long boat ride and things are still vibrating...
I bet if Eric added up two or more of his car engine horsepowers it wouldn't total 395. Maybe all of them and the Iseki thrown in too...
of course if he could buy gasoline for 1.76 a gallon, and diesel for 1.89, he might be in the garage turning up the wick on his engines.
time for a hot shower and as i was taught as a child, then one foot on a banana peel and the other foot in dreamland.
   / Good morning!!!! #43,914
Don, I understand, stuff I could do 2-3 years ago is becoming harder now. If you can reach it with a bar or something, turn the key on with the engine off, tap the clutch and pull the switch to see if it'll click in. Probably not though.
   / Good morning!!!! #43,915
Buckeyefarmer happy birthday to your father truly part of the greatest generation
   / Good morning!!!! #43,916
Home sweet home, safe and sound.
RNG, hang in there and keep chipping away.
Happy Birthday to Sodamo's wifey, and Buckeye's dad.
Getting hard to keep up with this thread. But it's the best thread in the world IMO.
   / Good morning!!!! #43,920
55 going to 78 and sunny, with rain coming tonight.
Drew, glad you got the trailer home safely.
Did some more "rock raking" on a bare ground food plot, and carried to my bridge approach. Between this rock and clay, and some sand dug out of the creek bed, I have built up the low spot...just hope it will hold next time it gets real wet.
1999 TRANSCRAFT FLAT BED 48FT TRAILER (A59905)
1999 TRANSCRAFT...
2022 FORD F-250 STX CREW CAB TRUCK (A59823)
2022 FORD F-250...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
2013 KOMATSU HM400-3 OFF ROAD DUMP TRUCK (A60429)
2013 KOMATSU...
159120 (A60430)
159120 (A60430)
2011 SHOP MANIFOLD TRAILER (A58214)
2011 SHOP MANIFOLD...
