Komatsu PC130
/ Komatsu PC130 #1
WoodChuckDad
Elite Member
Free Union, VA
Kioti RX7320 Power Shuttle Cab, Komatsu PC130-6
My excavator was delivered yesterday. I got about 3 hours of seat time. The learning curve is sharp. I tried to be gentle and learn how to finesse things, instead of relying on brute force. I cleared a about 6 trees that were 6-8 inches thick, and moved several debris piles and downed trees that were more than 12 inches thick. Just trying to get used to the controls get a feel for things. When the delivery driver was leaving he stopped to let me know he rutted up the neighbors driveway and yard a bit. So I took a break to go over and make nice with them. I got the tractor and used the bucket to smooth out the ruts some, then got down from the tractor with a shovel and my boots and tried to smooth things out even more. I will be going back with some grass seed next week. Good times....good times.
/ Komatsu PC130
/ Komatsu PC130
Sorry. I have a hard time getting pictures to upload.
/ Komatsu PC130 #4
Congrats on your new machine!!! I've found that most people go too fast and when I tell them to go slower, they don't understand, that I mean, go so slow you are barely moving. Once you get the feel for the controls, you will get faster, but until then, it's all about technique and not hurting the machine.
Do you have a good source for hydraulic hoses yet? Each one will have to be custom made. Here, I go to a company called Axxion. Napa also builds hoses, but they cost more.
Be sure to have plenty of the correct hydraulic fluid on hand.
Do you have a set of super large wrenches? Ming go from your standard sizes up to 3/4, then up an 1/8th in size to 2 inches. I also have quite a few that go up in 1/16th inch in size. That 15/16 inch wrench probably gets used the most for some reason. I also have quite a few big metric wrenches too, but found that with the big sizes, having everything in standard is close enough. Tractor Supply is where I bought most of mine
/ Komatsu PC130
Eddie, thanks for the recommendation on basic tools to keep handy. I will check out some of the tractor supply and harbor freight sets so I can leave them in the tool box.
/ Komatsu PC130 #6
I just picked up the 6 piece jumbo set from harbor freight. It goes from 1-3/8 to 2" by eighths. Paid 20% off of 49.99. Hard to go wrong with that. Even one of those wrenches sells for $30-40 at other places that sell imported tools. I think once you get up over an inch and a quarter, cheaper wrenches will work just fine for 99% of us. No need to spend big money on the nice stuff. I might buy a nicer 3/4" drive ratchet, but there again, I think HF sockets are pretty darned good for the money.
/ Komatsu PC130
When I was evaluating this excavator, I did not find a lot of owner or operator accounts on the internet. So I am adding mine to help anyone else out who decides to go this route. I've had it for 3 weeks now, and have put about 15-20 hours on it. I have used it to push down some smaller trees and stack them up to give me an area to keep it parked temporarily. In doing this, I discovered an old garbage pit. It looks like people dumped their household trash...bags of beer cans and wine bottles, etc. We dug that up and took it away. I started off being as slow and methodical as possible. Trying to learn how to control it. I have a 36 inch bucket on the machine and it handles that quite well, digging up buckets full of red clay and roots.. I may spring for an 18 inch bucket because that will allow me to power thru roots a little easier, and I can also use it for some other projects. I thought about a frost pick as some have recommended but think am going to hold off on that for now. one of the things I learned is "don't be afraid to dig a hole". Some the trees grow their roots deeper than others, and you have to get in there to loosen them up. busting up roots, leaves a lot of root material...it takes a bit more time to jump down off the excavator and pull that stuff out of the hole too, but I think it's worth the time, for what I want to do.
Dropping a rot ball on another stump is a great way to bust a lot of the dirt off of it.
Filling in the holes as you go is a must, especially if you have more stumps nearby to contend with.....Some models of excavator have a small blade on the front to push dirt around..mine doesn't. It would be convenient but I would still be going back over all of the area with the scarifiers and box blade to even out the soil before planting.
Making sure your windshield wiper blade is in serviceable condition before you need it, is a good idea.
Grease, Grease, Grease. greasing the zerks is an almost daily chore. There are a lot of them. you will go thru a lot of grease. But it gives you an opportunity to give the equipment a once over before you start running it for the day. I was greasing the zerk on the hydraulic thumb and discovered that the retaining pin for the rod that holds the thumb on the hydraulic cinder was missing.
I didn't have a bolt or pin that would fit, so I wasted more than an hour, driving to town on a Sunday to get one. Lesson learned....keep multiple extra bolts and pins handy.
The learning curve on using the excavator is pretty steep. Go slow, and don't get frustrated....Be gentle on the equipment..Don't beat the heck out of it. It's expensive and dangerous. I am certain I haven't come close to putting the kind of stress on the excavator that it has seen in the past, but I am trying to keep it running and not spend a fortune on repairs. It still will shudder and jump like a bucking bronco from time to time when you are trying to pull thru some roots and they give decisively.
Taking shallower bites with the bucket helps to control this .
All in all, I am very happy with my excavator. I put in 3 days of stump work this weekend, averaging about 5-6 hours a day and I have cleared about half an acre and I am getting faster as I go.
The Komatsu PC130 has a lot of power, is very easy to control and it uses less fuel than I thought it would.
/ Komatsu PC130 #9
Great pics and a nice review. I've read that even the 16 ton machines are tippy. You have to get to 20 tons to be stable. The blade is supposed to help a lot with stability. I also read that you should always dig with the drive gears in the back.
/ Komatsu PC130 #10
get a piece of very heavy I beam to use as a grader bar pinched with the thumb a log works ok as well.
greg
/ Komatsu PC130 #11
A ripper is a good option for getting roots out of the ground and for pushing trees as it easier to dig around the root ball.
Note; only the operator makes an excavator unstable no matter what size, undercarage type etc. Digging over the idler is very hard on the track adjuster and can cause the seal to blow out.It's also hard on the track chains as they are under tremendous strain causing premature wear on the pins and bushes. That came from an old UH series Hitachi operator manual. I did 14000hrs and 11000hrs on another and where sold with orginal track gear.One other thing, were possible track the machine with the idlers at the front, it lessons track wear by heaps. My 2 cents
/ Komatsu PC130 #12
Congrats on the new machine!!!
You sure can make a mess in a hurry with one of them, and you'll learn to fill those stump hole and grade as you get more time in the seat. Do you have another machine to compliment the excavator? I got rid of my old 951c Cat track loader when I got my ex, they would have worked well together.
Love the smell of fresh dug dirt! Have fun.:thumbsup:
/ Komatsu PC130
I'm a little unclear on which way to go here. So is the idler the plain round wheel in the front and the drive wheel is the sprocketed one in the back? When moving forward --pushing forward on the controls--the plain wheel is in the front. Am I supposed to back up to the things I want to dig?
/ Komatsu PC130 #14
Yes to youir idler/sprocket description.
I took Tonyoz comment as if you need to "walk" the machine for any distance, drive forward (sticks & idler forward), I understand this to be true also. When digging, I'll just dig in whatever position the machine is in rather than spinning the machine just to be pointed a certain direction. Just remember to look down (at your sprocket or idler) before you move to see what direction to move the controls.
/ Komatsu PC130
Ok. That makes sense. And in answer to your question, I do not have any other equipment except a tractor with FEL, grapple, and box blade
/ Komatsu PC130 #16
That will do. It's just nice to have something meant to move stuff after you've grubbed it out with superman's arm.:laughing: Warning; There is no cure for the heavy equipment "bug", only more of it.
/ Komatsu PC130
Put in a full day of work today, in the rain. I was in the tractor shuttling stumps back and forth. My son was in the excavator. He works slow but steady, and did great work today.
/ Komatsu PC130 #19
What's the weight of that machine? I've a few hours in a 50,000 lb. machine and thought it should really have more power. Almost seemed detuned. It was a rental and a Cat.
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A64556)
2014 Ram 1500 4x4...
2012 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2012 Caterpillar...
2023 CATERPILLAR 303.5CR EXCAVATOR (A65053)
2023 CATERPILLAR...
2015 Ford F-250 Knapheide Service Truck (A61573)
2015 Ford F-250...
2001 Freightliner FL112 T/A 5 Car Hauler Truck (A64194)
2001 Freightliner...
2010 Ari Hetra HDML-8 15,000lb. Heavy Duty Mobile Column Lifts (A61572)
2010 Ari Hetra...
