Titan Rim Crack
/ Titan Rim Crack #1
BWP88
Jacksonville, FL
Mahindra 5555
New to forum and having issues with Titan Rim cracking. First was the left front and now the right front with less than 30hrs on tractor. The cracks are occurring over the rims clamp welds. What could be causing this issue? I have checked all specifications for ag tires. Running recommended pressures and all. Just regular loader work. Attached is a photo of leak. Any ideas what could be happening other than manufacturer defect? Thank you
/ Titan Rim Crack #2
Mahindra appears to use very weak rims. If the bolts arent good and tight the loader loads cause front rims to crack at the spot welds that attach the bracket to the rim. Tires have to be demounted to fix. Then tighten those bolts to their strength limit and it wont happen again.
/ Titan Rim Crack
Ok so i need to take the tire off the rim and then torque the clamp bolts? Or just take the wheel off the tractor and crank down on those puppies? Just trying to be %100 sure. These things are obviously temperamental creatures... Haha
Thank you for the help!
/ Titan Rim Crack #4
The tires have to come off so that the rim cracks can be welded from the inside.
/ Titan Rim Crack #5
Welcome to TBN........................
Agree with the cause of the problem.
At less than 30 hours those wheels should be repaired or replaced under warranty by your dealer..
2 Grain Racks (A60352)
2003 John Deere 110 Backhoe (A59213)
2003 John Deere...
2017 Xtreme Telescopic Telehandler (A60352)
2017 Xtreme...
2017 KALMAR OTTAWA T2 4X2 SPOTTER TRUCK (A60430)
2017 KALMAR OTTAWA...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
