ovrszd
Epic Contributor
- Joined
- May 27, 2006
- Messages
- 33,727
- Location
- Missouri
- Tractor
- Kubota M9540, Ford 3910FWD, Ford 555A, JD2210
I think you'll find a need for some rear ballast.
I don't see a gripping problem. The way the cylinder is setup it will grip very tightly. Leading to the issue of shearing when you want to pull.
Be aware that you will put stress on your FEL that it isn't designed for. Example being if you clamp onto a tree that you can't simply pull. Then you decide to reverse the tractor and try to lift and backup. Your FEL is being forced to "roll back". It's possible to bend the bucket cylinder rams.
