Welded fence braces
/ Welded fence braces #1
crystallake
Jonesboro, AR
MX5100HST
Planning to put in about 800 feet along a county road with two gates in the line. Going to use barbed wire. Anyone have a good design for H-Braces made from square or rectangle tubing.
/ Welded fence braces #2
Did mine from 3" square tube, .187" wall - capped the tops to keep rain out, put 6" "elephant feet" (flat plate) on bottoms, set them up so 3' in ground, 5' above with cross piece (also 3" tube)centered on the above-ground part - drilled holes with 1-man auger, dropped a shovelful of gravel in holes, set the brace, filled with Sakrete, troweled off slightly above ground and sloped AWAY from post. Sorry, no pix - my friends laugh at me enough (till they can't figure out how to accomplish something :rolleyes:)
10 years later - all still in place, couple have soil around the upper 3-4" of concrete eroded, still holding tension (if you're a musician, think "middle C" :laughing:
Things I'd do different - No way I'd do another corner (double H) that way again, too hard to get all holes lined up and too heavy to put in without a helper and a loader or backhoe. Even the single H gets too much for painless install.
Also - if you start with NEW steel, ask for 24' lengths instead of 20, you can get 3 8 footers per stick that way - good chance you'll end up with less scrap.
Next time (and unfortunately there WILL be a next time) I now have a big enough genny, air compressor, air powered T post driver and inverter welder, so I will sink posts separately (either drive them in or same as before), THEN I'll cut cross piece to fit between the posts, and the cross piece will get welded in ON SITE and oriented so corners of tubing are UP and DOWN so water won't stand. Drowning it in rustoleum optional, but a good idea...
BTW, if you rotate the horizontal tube that way, it should be 2", it will come out just shy of same width as the 3".
Field fencing usually comes in 20 rod rolls (330 feet) so that's how far apart I'll do H's, then fill in with air driven T posts.
My project is just under a half mile and I'm too old to wanna hurt myself any more than necessary, so before it happens I will be building a field fencing unroller that will be kinda like a bale spear with a platform behind it, so I can go to the pallet of field fencing, spear a roll, stand it up, run the end thru the tensioner, drive to the end of the last roll, tie off, drive 330 feet, tie off, repeat as necessary -
I'm kind of a "mad scientist/dangerous inventer" type, so right now this part is just random neuron firings in my head - sorry, no plans/sketches yet, too many other projects in line before it... Steve
/ Welded fence braces #3
Plan attached below.
Bruce
H
/ Welded fence braces #4
Oh, 'nuther thing - if you leave the upright where the gate will hinge, TALLER by a couple feet - it can be the anchor point for a tension cable so the gate won't sag... Steve
/ Welded fence braces #5
I bought some surplus 2" Sch 40 galvanized pipe to make my H posts. Cost me about $30 per 24' joint. Welding galvanized material sucks but, it'll most likely outlast my grand kids.
I set the post individually and then cut, notched and welded the cross braces in the field.
/ Welded fence braces #8
What kind of T post driver do u have? Like it (pros/cons) Was thinking about a gas powered one but air might be cheaper since I have genny and compressor.
/ Welded fence braces #9
For maximum strength, you want the cross piece to be 2/3's of the way up. Not in the middle, not at the top. If you put it somewhere else, you will probably never notice the difference, that's just the strongest place. All corners should have diagonal bracing with the pipe attached 2/3's up and into the ground several feet. The deeper the better. Usually you set a post, or pipe straight into the ground with about a foot sticking up. Then weld it all together.
Depth of posts is where most people get into trouble. Soil moves when it gets wet and freezes. This is when posts get pushed out of the ground, so you want to be deeper then the how far down the ground freezes. Generally we're fine with 3 feet in East Texas, but in some soils, 4 feet is hit or miss if it will move on you.
I've spoken to several fence builders and they claim that a post driven into the ground will hold better then one set in concrete. One guy told me that he did a test for a client. He drove one post in, then set the other in concrete. He then had the owner of the ranch pull each one out with his tractor. The one in concrete came out easier. I trust him, and believe his story, and that's how I'm planning on doing my next big fence project.
/ Welded fence braces #10
On my ranch in so TX I have a number of 2 7/8" pipe posts that were driven in. The posts are 10', driven in 5' and most are part of a welded H-brace. Some have been in for about 4 years and all are holding well. Since I don't have a driver, if I set a post I use a 4' hole (for H-braces) and set the post in concrete. Line posts are usually 8' 2 3/8" and set in 3' concrete. All done that way have held up well. Lately I have had access to used telephone poles. I have been setting 9' poles in 4' holes, well tamped. Most have been part of H-braces and gate posts. If the fence is a relatively short run I will use a single H. If it is at the end of a long run, I will use a double H. YMMV
I might add that my hydraulic post hole digger will go to 48" but still leaves some loose fill in the hole. To get that out, I put longer handles (about 6' of 1/2" pipe) on a manual post hole digger. that gets the bottom of the hole clean.
Thanks fellows, especially Bruce, you one smart Dude. :cool2:
/ Welded fence braces #12
C4 - "What kind of T post driver do u have?"
99E-M Post Driver 2 - 7/8" Max Diameter Recommended For Military Use and Drill Stem - Rohrer Manufacturing
I chose that one 'cause it can handle up to 2" square tubing - bought it with extra T post adapter and one 2" square adapter. Won't make THAT mistake again, they charge quite a bit for adapters - if you have basic machining ability (drill holes and tap them) AND a plasma or Acetylene torch you can make your own, up to max of the specific model you get.
I wanted a bit more "oomph" than a straight T post (only) driver, so I made an adapter with 2" square tube upper, 4" square tube lower - a 4x4 is 3.5" across, fits into 3/16" wall 4" square tubing - I set up a jig for my chop saw to "pencil point" 4x4's. After cutting I soak the ends in a pail of (IIRC) Copper Green, then as long as I don't try this in dead of summer, the bigger unit will drive a 4x4 into my clay soil in a minute or two.
Even this larger unit will run just fine on my little "double hot dog" airless compressor. Only downside, other than higher $$$, is weight (as I discover every year :( )
HTH... Steve
BukitCase tell me about Copper Green, I thought it was a wood preserver.???
Eddie, I dont understand what you meant:
" Usually you set a post, or pipe straight into the ground with about a foot sticking up. Then weld it all together."
/ Welded fence braces #15
Sorry, wasn't totally clear about the "4x4's" - Copper green IS a wood preserver, I was referring to pressure treated 4x4 posts driven into the ground - I cut "pencil points" on the wood posts, but PT lumber doesn't really get soaked very deep so when you cut it, it'll last longer if you re-soak the cut part before you drive the posts.
The OTHER 4x4 I mentioned is ACTUALLY 4" x 4", as in steel tubing - I used a 6" long piece of that, capped it with 1/2" flat bar, then welded a piece of 2" square tube on that cap and capped the top end of the 2x2 - this is because the air powered driver I have normally fits over whatever post you're driving, but they don't sell one big enough to fit a 4x4 wood post directly (plus they cost about $100 more, and I was already at $700)
With my adapter, I insert just the adapter into the post driver, tighten the set screw, then slide the wood 4x4 into the BIG end of the adapter, tip it all up vertical and flip the trigger.
If any of this is still confusing, check out the link I posted - they have a couple videos of the process... Steve
/ Welded fence braces #16
Couple of pictures showing what I'm describing. Just the H brace might be alright, but if you have a long run, bad soil or you just want to make it as strong as possible, you need to add diagonal bracing. The way I've seen it done is that they drive a shorter length of pipe into the ground somewhere around 4 to 5 feet down with one foot sticking up. Then they cut and weld their diagonal brace from that short length of pipe sticking up to the end of the H brace.
Landhonor No Till Seed Drill (A62679)
Landhonor No Till...
CASE CX160C EXCAVATOR (A65053)
CASE CX160C...
Challenger MT275B 40HP 4WD Utility Tractor w/ 76in. Rotary Brush Cutter Attachment (A59228)
Challenger MT275B...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2014 Ford Transit Connect Van (A61573)
2014 Ford Transit...
Kubota V3300-T-E3BG Turbo Diesel Engine - 3.3L - 84 HP - 2018 - Tier 4 Interim (A63689)
Kubota...
