Diesel Oil use in a Cub Cadet Kohler 25 HP engine . . . good, bad, or not the best ?
   / Diesel Oil use in a Cub Cadet Kohler 25 HP engine . . . good, bad, or not the best ? #1
AxleHub
Elite Member
Western Wisconsin
Massey scut 2015 GC1715
Greetings,
I'm looking for opinions on the use possibility of a high quality diesel engine oil in a Cub Cadet 25 hp Kohler gas engine.
I have a 2011 Cub Cadet I 1050 zero turn tractor. It has the 25 hp Kohler gas engine and has just 85 hours use. I bought it from a dealer (his personal unit) last year with 59 hours on it. I changed oil and filter and used 10w-30 Havoline regular oil.
I also have a new subcompact massey tractor that I switched from using dino oil to full synthetic mobil one delvac 5w-40 diesel oil.
I understand diesel engine oil has some benefits for diesel engines in absorbing suet. And certainly full synthetic can be good for lubrication. Normal tractor recommendation is for 5w-30 dino oil but the synthetic seems easier on the engine for cold starts and heat issues.
So I'm wondering if this same diesel engine oil would be a good thing for my Cub Cadet gas engine.?
Is there something about diesel engine oil that would not be good for a gas engine?
Input and opinions welcomed :)
   / Diesel Oil use in a Cub Cadet Kohler 25 HP engine . . . good, bad, or not the best ? #2
No problem I use rotella t or chevron Delo 400 in all my engines gas and diesel.
   / Diesel Oil use in a Cub Cadet Kohler 25 HP engine . . . good, bad, or not the best ? #3
If that oil has an s rating high enough, go for it!
   / Diesel Oil use in a Cub Cadet Kohler 25 HP engine . . . good, bad, or not the best ? #4
Just changed oil in my 23hp Kohler command using the Kohler 10w30 branded oil. It is rated SJ but also has a CH-4 diesel rating which would cover most diesel engines before the CJ-4 came to market. I would not hesitate to use 10W30 Rotella if I did not have access to the Kohler oil. It seems that since their Kohler branded oil is considered diesel rated oil that they think this is the way to go.
   / Diesel Oil use in a Cub Cadet Kohler 25 HP engine . . . good, bad, or not the best ? #5
Been using Delo 400 15w-40 in every machine I have for about 20 years, gas or diesel. So far, so good.......
Greetings all,
I may have miscommunicated so I thought I would correct any wrong impressions. The Diesel Engine oil I mentioned about using is not a Rotella product. It is a Mobil 1 Delvac ESP 5w-40.
Its certifications are. API CJ-4, CL-4 PLUS, CL-4, CH-4 /SM, SL
and then some cummins and catepillar and acea approvals as well.
   / Diesel Oil use in a Cub Cadet Kohler 25 HP engine . . . good, bad, or not the best ? #7
If the S certifications meet your gas engine spec.. go for it! ;)
   / Diesel Oil use in a Cub Cadet Kohler 25 HP engine . . . good, bad, or not the best ? #8
Diesel engine rated oil has a higher zinc content, important for flat tappet (non roller rocker/lifter) engines. Just got back from Kawasaki schooling, and they recommend a "diesel engine" rated oil for all thier engines now. I mostly run Shell Rotella T in most everthing I have, granted my lawn tractor is a diesel, but I also use it in my B&S powered Snapper push mower.
   / Diesel Oil use in a Cub Cadet Kohler 25 HP engine . . . good, bad, or not the best ? #9
I have an LT 1050 with the Kohler Command Engine.....Have run Mobil Delvac 15w/40 since new (it's a 2005 model), without any problems whatsoever. I also run it in the transmission, with a once a year change interval. This mower has logged 1,130.3 hours, and still runs like a top.....no smoke, no makeup oil between changes.
   / Diesel Oil use in a Cub Cadet Kohler 25 HP engine . . . good, bad, or not the best ? #10
Learn something new every day..... and I certainly would have guessed wrong on this one.
PALLET TOTE OF MISC PIPE FITTINGS (A58374)
PALLET TOTE OF...
VINTAGE EVINRUDE MOTOR (A58374)
VINTAGE EVINRUDE...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A56435)
2023 New Holland...
Mini Skid-Steer Hydraulic Side Shifting Forks (New/Unused) (A59225)
Mini Skid-Steer...
(INOP )JOHN DEERE RIDING MOWER (A58374)
(INOP )JOHN DEERE...
30ft Highway Trailer Co. Lowboy (A56435)
30ft Highway...
