Need help with NH TN95A 4WD
   / Need help with NH TN95A 4WD
This is what I got today
Server Error in '/' Application.
Object reference not set to an instance of an object.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.NullReferenceException: Object reference not set to an instance of an object.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[NullReferenceException: Object reference not set to an instance of an object.]
CNHOrderingWebsites.RetailLogin.Page_Load(Object sender, EventArgs e) in H:\CNHOrderingWebsites\CNHOrderingWebsites\RetailLogin.aspx.cs:52
System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) +51
System.Web.UI.Control.OnLoad(EventArgs e) +92
System.Web.UI.Control.LoadRecursive() +54
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +772
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.34280
   / Need help with NH TN95A 4WD #12
I get the same thing. Server error. Attached
GOOD NEWS
I went by a NH dealer of heavy construction equipment. They had a hard time finding a manual on line with over 3600 manuals. They printed a letter size page out for me. I could not read it with lots of light and magnifying glass, much less color in the lines to trace the wiring.
I to it to FedEx Office and they printed it for me on a 3ft x 4 ft sheet of paper. I can read it now.
Bad news.
Colored in the lines to connectors. End of story. It is just the main harness.
Looks like I will test the switch. Then try to figure out which relay. Wires and connector from there if I can figure them out without a schematic.
   / Need help with NH TN95A 4WD #15
I tried it as you say and still does the same. I get to the 1st page (attached) then when click on New Holland I still get the server error.
Tried the revised link by removing the spaces between the w's and get a new page error which locks up my computer.
May be a problem at the site. I've had some 502 bad gateways trying to log on this in the past week too.
Maybe the OP will have better luck connecting to the link.
1608 (A57192)
1608 (A57192)
Hose Reel (A55758)
Hose Reel (A55758)
2019 Freightliner M2 106 Johnston VT651 8.5 Yard Street Sweeper Truck (A56858)
2019 Freightliner...
2015 Ford Transit Cargo Van (A54814)
2015 Ford Transit...
2020 Club Car Onward HP Li ION Electric Cart. (A56859)
2020 Club Car...
Husqarvana Riding Mower (A56857)
Husqarvana Riding...
