Need help with NH TN95A 4WD
   / Need help with NH TN95A 4WD #1
ch1ch2
DFW, TX
IH 584, NH TC33DA, NH TN95A
I recently replaced the clutch assembly on my tractor and after putting it back together I can not disengage the 4WD. The 4WD switch is on the dash. At this point I am guessing/hoping it is in the switch. I also have some wires that I do not know where they go or what they should do.
I bought this tractor used and it looked like a lot of features had be remove to just a basic tractor.
Does anyone have a wiring diagram or know where I can get one?
A wiring diagram with color codes would be of great help.
I had asked the dealer about buying a service manual. He said he would not sell it to me unless I just wanted to spend $1000 or more and I would get books that are over a foot high. He went on to say I might be able to buy a IT manual but all he had was on old tractors.
   / Need help with NH TN95A 4WD #2
Here's one place. Says its a 900 page manual, but it covers more than one model and under $300. Can't vouch for the seller though as I've never dealt with them.
New Holland Manual
I looked at the link.
I can not find any where it says it has a wiring diagram or wiring schematics.
   / Need help with NH TN95A 4WD #4
Unless another TN95A member is a member who has the books you need, you may be at the mercy of a dealer. Since yours isn't willing to print off a copy check with another dealer.
   / Need help with NH TN95A 4WD #5
Object moved
Search around here at the NH publications website. You may be able to buy specific sections of the service manual rather than the whole. Schematics are typically found in the electrical section.
Object moved
Link says object moved.
The link was no good.
Can you please try again?
If I can find something today I will try another dealer. Thanks.
GOOD NEWS
I went by a NH dealer of heavy construction equipment. They had a hard time finding a manual on line with over 3600 manuals. They printed a letter size page out for me. I could not read it with lots of light and magnifying glass, much less color in the lines to trace the wiring.
I to it to FedEx Office and they printed it for me on a 3ft x 4 ft sheet of paper. I can read it now.
   / Need help with NH TN95A 4WD #9
The link worked when I posted it, but not now. I went in to the site from a different direction and got the same result as using the link. The site must be having problems; please try later.
Freighliner Tender Truck (A55315)
Freighliner Tender...
2009 International 7400 T/A VacCon V311LHA Combination Sewer Jetter Vacuum Truck (A56858)
2009 International...
2015 Ford F-550 (A55973)
2015 Ford F-550...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
