Ford 4630 Steering Problems
   / Ford 4630 Steering Problems #1
houser52
Gold Member
Cherryville, NC
Kubota M7060HD, Kubota L3600
My dad has a 4630 that is about 20 years old and it has given him great service until now.
Just recently the steering has been giving some trouble. When turning the steering wheel the front wheels won't move even though you are still turning the steering wheel. Then it acts like something "catches" and it steers okay. When the engine isn't running you can turn the steering wheel all the way around and the front wheels don't budge.
The power steering fluid level is fine. Any idea of what to look for?
   / Ford 4630 Steering Problems #2
My first thought is the steering cylinder is worn and allowing hyd. fluid to bypass the piston inside the cylinder until the pressure drops enough to overcome the flow. May be time to rebuild the steering cylinder.
Thanks. Would a worn cylinder also cause the steering wheel to spin freely with the engine not running?
   / Ford 4630 Steering Problems #4
If the steering is completely hydraulic the wheel will spin because there is no hydraulic pressure to push the cylinder rod.
MACK T/A DUMP TRUCK (A58375)
MACK T/A DUMP...
2017 JOHN DEERE 437E KNUCKLE BOOM LOADER (A52705)
2017 JOHN DEERE...
Mini-Excavator Quick Coupler (New/Unused) (A59225)
Mini-Excavator...
Miller Bobcat Welder/Generator AC/DC Welder, 1 Phase & 3 Phase Generator, S/N M0321574R, Kohler Gas (A59076)
Miller Bobcat...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
2012 Ford Focus Sedan (A56859)
2012 Ford Focus...
