Backhoe Backhoe won't move
/ Backhoe won't move #1
kwbretired
Horseshoe Bend, Arkansas
Case 485, John Deere 5425, & John Deere Skid Steer 333D
Well I found a new problem with my Case 580M backhoe, it won't move. Hydraulics work on the front end loader and the backhoe just no forward or reverse. It backed up about 20 feet then when I tried to go forward it wouldn't go anywhere. Had to use the backhoe to push it back under the shed and now reverse doesn't work. Any clues as to what could be wrong? It has been setting up for about 1 1/2 years. I just got it running yesterday, mice eat some wires.
Kenny.
/ Backhoe won't move #2
Kenny first buy a new trans hydraulic filter then pull the old on off and see if it's sludged up inside if so pull the screen out of the hydraulic tank and clean it up as well . I can't think of any other reason it's not moving other than it's in neutral of not getting H. fluid. Oh one other thing does that machine have an electric clutch button on the loader control maybe mice were into those wires as well.
/ Backhoe won't move #3
Are you 100% sure the driveshaft is connected? I've broke mine twice so far. It happens.
Did you inspect your hoses?
Do you have anything along your hose line that diverts or adjusts the pressure of your hydraulic pressure?
The drive shaft is fine, I was under the backhoe several times today replacing two fuel lines. I didn't notice any hose issues. In the next couple of days I'm going to drain the transmission fluid clean the screen where ever it is then change the filter and fluid. I have to figure out where I can buy a filter and what fluid goes back in the transmission. Not sure which filter is the transmission filter, there are filters all over the place but I will assume it will be the one closest to the transmission.
/ Backhoe won't move #5
Is it a hydrostatic? If so, after you replace the filters and fluid and it still won't move check the linkage to make sure it's connected, after that I would be checking pressures at the transmission for possible bad charge pump.
Randall
It's not hydrostatics, it has a 4 speed shifter with a button on it that has to be pushed to change gears. Can anyone give me a part number for the transmission filter and what fluid goes in the transmission. I'm going to try and pick it up tomorrow.
/ Backhoe won't move #7
IIRC (from one a friend had many moons ago), it has either a solenoid controlled wet clutch or a torque converter sitting in front of the transmission.
I think it was a torque converter.
Aaron Z
/ Backhoe won't move #8
Lift the bucket and set the safety prop. Pop the hood. Lift the curtain at the back of the engine, or better yet, take it off. Looking at the top of the transmission, there is a valve block with 2 solenoids on either side of the valve block. This valve assembly controls forward/reverse. Make sure you're getting power/ground on either solenoid when checked in forward and reverse, ENGINE OFF, key on! Have also seen the snap ring break on the control valve in that valve block and keep it from engaging forward/reverse. Good luck.
Thanks, I will check it out in a couple of days. I'm going to change the transmission fluid and filter first and see what happens then I'll check the solenoid so. Thanks for all the help.
/ Backhoe won't move #10
My NH backhoe has a forward and reverse lever on the side of my steering wheel. It's gone out on me and nothing would happen until I replaced it. Took me awhile to figure that one out. There is a good chance that something similar exists in yours. I would think that if it's a bad filter or dirty fluid, it would still move, just slowly. Since it's not moving at all, it makes me think that something isn't activating, or is broken.
Napa and ABC auto have all the hydraulic filters that I've ever needed for both my NH and Case tractors. Bring in the old one, or just the numbers off of the side of it and they will get it in a day or two.
/ Backhoe won't move #11
Eddie's right if it was fluid in should at least move a bit. So the button on the gear shift operates the clutch solenoid check it's allowing the clutch to engage, and that the shuttle is actually working like Eddie said as well.I'll look at my service manual today and see if I can come up with something I can help you with.
/ Backhoe won't move #12
The transmission filter on that machine is in behind the starter and can be difficult to find it's smaller that the hydraulic filter which you access from under the hoe.
My neighbor came over this morning and he picked the whole machine off the ground, put it in gear and the wheels turned, even sped up when hem mashed on the accelerator. He fooled with it some more and it quit again. We can hear a light buzzing sound under the joy stick for the loader, don't know what that is. It's the same buzzer when you turn the key to the right but not to the stat position but lower tone. We checked the transmission fluid and it was very high and a milky green color. I bought 20 gallons of transmission fluid, hydraulic filter and the transmission filter this morning. Will change fluid and filter tomorrow. You were right, the transmission filter was hard to locate but I found it. Will replace both filters with WIX filters. There is another problem and I guess this could be related, only one brake works. I had talked to the case people and they said it was most likely some Orings went bad on the brake piston and that fluid either from the transmission or the hydraulic system (can't remember) is passing into the other system. I plan on having this fixed before too much longer.
Kenny
Billrog, where is this screen that needs to be pulled and cleaned? Is it behind a little cover plate that has two small bolts at the bottom of the transmission or is it on. Line somewhere?
/ Backhoe won't move #15
Kenny
Maybe a relay thats buzzing?
/ Backhoe won't move #16
Kenny unless the filter is full of crap don't be concerned about the screen I pulled it out once on mine and it was clean as a whistle. I'd have to look at my Hoe to figure out where it is again. As for the buzzer it may be the emergency brake when the handle linkage gets warn you have to wiggle it to stop the buzzer often.
Also I can't remember if the screen is for the tran. or the hydraulics.
Got the transmission oil drained and the new filter installed. Got to tell ya it must of been He-Man that put that filter on. Had to use a huge pair of pliers and then use a 2' cheater to break the filter free. Plus where Case put the filter, they didn't want anyone to walk by and take it off. LOL. The oil was really funky. How is the fluid level support to be checked - with the engine running and warm or engine not running? The oil level was very high when I checked it just before I drained it and the engine was not running. I'll leave the oil out until I find here the screen is I'm suppose to clean.
/ Backhoe won't move #18
2wd tran refill capacity 11.9 lt. 4wd refill capacity 14.4 lt. this is with or without filter change.Then park on level ground and check with engine running.Any where between the add and full mark is good. The M has no screen to worry about it was my K model that had one. To the right and behind the trans filter there's a breather for the trans. it's suppose to be taken out and cleaned with solvent every 1,000 hrs.
As for the alarm engine oil low,engine temp. high, park brake on and you move the direction control lever, or you turn the seat when the control lever is engaged.
The only thing I can find on the direction control lever electric circuit is that it has a feature that allows you to move the machine a short distance in the event that the control lever receives intermittent signals that shift the tran into neutral. By shifting the lever in the opposite direction you wish to travel and back again it will engage for 5 sec. ONLY for emergency use. So I would trace the circuit that deals with this maybe a fuse or a relay or a mouse problem.
/ Backhoe won't move #19
Took the cover off behind the steering wheel and there are 2 shuttle relays, 2 clutch relays and a forward and backward one maybe 1 of the shuttle relays is faulty ?
OK, have some more information. When I drained the transmission, it only looked like about 5 gal of oil came out, should be 14 or 15 gal. I filled the transmission this morning amid it only took about 4 gallons. I'm confused what didn't I drain? I just removed the plug on the very bottom of the transmission.
After filling transmission with new oil I started the backhoe and let it warm up a few minutes. I raised all four tires off the ground, put in gear and pushed the shuttle shift to forward position and the wheels started turning. Put in reverse and the wheels turned backwards. Put back in forward and left it running there for about 20 minutes to warm up the oil in the transmission and to circulated the fresh oil. Went through all the gears and checked both forward and reverse, all worked. I thought all right it's fixed - it's not.
, the wheels quit moving. Shut engine off waited a few minutes then restarted, working again. Lowered backhoe onto the wheels. Tried moving backwards, it did, tried forward, it did. Great. Backed out from barn and started working with the fel just to see if it was doing OK. Wheels quit moving again. Stopped engine the immediately restarted then tried moving nothing. Shut off engine foe about 5 minutes then started and the wheels moving again. This repeats it self several times, it works for a very few minutes then quits. Stop engine for 5 minuets and it worked again but only for another very few minutes. I'm about to pull my hair out. What the heck is going on. I'm fixing to go check the transmission vent as suggested before then I'm going to pull up the floor board to see if I see wiring problems on top of the transmission.
I pulled and checked all the fuses yesterday, found 3 that needed replacing. I pulled the cover under the joy stick this morning, cleaned out a rats nest but didn't see any more wires chewed. I did find the buzzer that is going off while the shuttle is in gear, it's not the same one that sounds when the key is turned to on. This buzzer is down low almost to the platform.
Hopes this new information will someone a clue what's happening. Thanks again.
Kenny
2015 Kenworth T880 QMC 8060R 40 Ton Tri Axle Straight Boom Crane Truck (A64194)
2015 Kenworth T880...
2018 Ver-Mac S/A Solar Towable Speed Trailer (A64194)
2018 Ver-Mac S/A...
2025 Wolverine PT-16-02C Class 2 Three Point Hitch Skid Steer Attachment (A64553)
2025 Wolverine...
2015 Chevrolet Impala Sedan (A64557)
2015 Chevrolet...
2022 Forest River GANS58SA 8ft. S/A Enclosed Cargo Trailer (A64557)
2022 Forest River...
2018 JOHN DEERE 35G EXCAVATOR (A65053)
2018 JOHN DEERE...
