2415 cold start (glow plugs)
/ 2415 cold start (glow plugs) #1
boxygen
Gold Member
Southern Maine
Mahindra 2415 TLB 1967 Holder AG3, articulated 4wd
Hi all,
Its been a while since I posted here. My 2415 is now 8 years old and has been pretty trouble free. Just recently it has developed a cold start issue. We had some very cold weather (0 degrees) a few weeks ago when I first noticed it. It has always started no matter what the temp before then. I checked the fuel filter at that time and it was very dirty and surprised it started at all before that. I had an extra and put a new one in. It still would not start after filter change. I gave it a small whiff of starting fluid and it fired right up. Once even a little warm, it would fire up no problem. The glowplug light lights up when the key is turned on. It illuminates and goes off after a normal amount of time, but doesn't seem like they are working. Given the suddenness of the problem, I have a hard time thinking they all went dead at once. Isnt there a relay in between the timer and the glow plugs? Is this a common problem or even a possibility. If anyone has any thoughts or diagnostic thoughts, please let me know. I just remembered that I have a shop manual I bought some time ago somewhere. I will see if I can find that.
/ 2415 cold start (glow plugs) #2
put 12vs to the glow plug rail manually/carefully and see if it fires like normal... there is also a fuse and a relay. before you change the relay pull the ground cable off the battery and the frame and clean it well. even clean the frame up also... if it fires with the 12v jump and a clean ground but still not without the jump you need a new relay
Thanks Navasot, I will give those things a try.
/ 2415 cold start (glow plugs) #4
/ 2415 cold start (glow plugs) #5
Hi all,
It sounds like you may have a bad glow plug, you can disconnect the wire and the strap that connect the glow plugs together and check the resistance of each with an ohm meter to see if one or more are burned out. Don't know the exact spec. but would guess around 1.5 ohms for a good one.
2015 Ford F750 Service Crane Truck (A62613)
2015 Ford F750...
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A59823)
2018 FREIGHTLINER...
2019 Merlo TF 42.7 (A60462)
2019 Merlo TF 42.7...
2015 Peterbilt Dump Truck (A55973)
2015 Peterbilt...
1998 Mazda B2500 (A57149)
1998 Mazda B2500...
2025 12v Fuel Pump (A61568)
2025 12v Fuel Pump...
