AlbionWood
OK, I have read a few threads about different ways to add a valve to operate a thumb or grapple, and am still not sure what the pros and cons are. I need to decide which way to go soon.
My tractor: Ford NH 1920, 7 gpm hydraulic gear pump, has FEL with 2-spool valve. Also has single remote valve mounted on rear fender to operate toplink, run off the hydraulic manifold block.
If I understand correctly I have 3 options:
1) Replace single remote valve with a double valve
2) Add a diverter valve on the bucket rollback lines
3) Add a 3rd function valve
If I can just take the single remote valve out and replace it with 2 valves, maybe that's the easiest (no electronic switches etc), but it would require running long lines from the back up to the front, under the tractor, which sounds like a bit of a pain.
Diverter valve seems pretty simple to install and would allow feathering. Kind of leaning toward this one.
3rd function seems like the most complicated installation. Are there advantages that make this worthwhile?
Thanks for any advice you can offer.
