How would you suggest to clear this?
   / How would you suggest to clear this? #11
I have cleared acres of blackberry brush with a Piranha toothbar........well made product.......they will custom make one for your bucket. I never take mine off. Definitely a backhoe for the stumps.
BXpanded Piranha Tooth Bar
   / How would you suggest to clear this? #12
Also have your hand on the pto control in case you get stalled.
Look what arrived today. ..
   / How would you suggest to clear this? #14
I cut 8' tall brush with a 15hp grey market Shibara and a 4' Kingkutter rotary cutter. I cut anything over 1 1/2" with a chainsaw and let the brushmower do the rest.
   / How would you suggest to clear this? #16
I have lots of dense shrub between trees that I would like to clear to bare earth. It doesn't look like much now, but in the summer it's so dense you can't see through it.
Can a bush hog handle 1"-2" scrub brush? I've been using the bucket to dig/pry out what I can. It's working but seems like I'm making slow progress.
I've already bought a toothbar to help with the tear out, are there any other attachments I should buy?
If you get a Heavy duty bush hog yes, you can take out up to 2" scrub brush... they are not all made the same though.
Yeah, it's looking like I am going to have to pay to play. The KK I've found locally is an xb line. I've heard that that's the cheap light weight model. Guess I'll have to keep searching.
   / How would you suggest to clear this? #18
I've cleared a a lot of brush 2-3" diameter with my medium duty Bush Hog BH27 Which has a 3" rated cut. the side skirts are 1/4" plate. I've mowed over 4-5" stuff accidentally it usually just skims pieces off. No dents or irregularities in the deck.
Most of the used KK I've seen used look like they were used to clear mine fields. Maybee they do make some heavy duty models but the ones I've seen look like they should be relegated for field grass only.
There are some medium/ heavy duty 4 and 5 ft cutters. I'd look at land pride, woods, bush hog, JD I'm sure there are others
Some other pointers:
Make sure you have a good skid plate setup to protect hydraulics and filters.
Also the last thing you want to do is push over a tree and then have to back up without shredding the tree. Even with a skid plate, the limbs find themselves in bad spots.
On the seventh day, I rested after successfully making play room for the little ones.
Thanks all for your input. The BXPANDED piranha is amazing.
Diamond C Trailers 26ft T/A Flatbed Tilt Trailer (A55787)
Diamond C Trailers...
2020 DRAGON ESP...
2019 Freightliner Bucket Truck (A55973)
2019 Freightliner...
TRAILBLAZER 325E FL GAS WELDER/GENERATOR (A54757)
TRAILBLAZER 325E...
Black Steel Diamond Plate (A55758)
Black Steel...
Deere 35P (A53317)
Deere 35P (A53317)
