X485 - Leaking oil at sensor to right of oil filter
   / X485 - Leaking oil at sensor to right of oil filter #1
tdurham
Southaven, MS
X485
I have just noticed that oil is slightly leaking from the sensor to the right of the oil filter. It has a single wire connected to it. Can anyone tell me what this sensor is and should I just get a replacement sensor to correct the leak?
Thanks for any help!
Tim
   / X485 - Leaking oil at sensor to right of oil filter #2
Have you tried tightening it up? or removing it to see if an o-ring or gasket is messed up? or if it then looks like the sensor itself is leaking?
I didn't find what you refer to in jdparts.
I cleaned it up and removed the sensor, put some thread tape and a rubber o ring on it. But it is leaking at the end I believe. I think it is for oil pressure ???. Anyway you can see from the picture it is dripping as I took the shot.
Maybe this whole part needs to be replaced. It is a metal piece with what seems like a ceramic insert. The wire attached to the end of the hard rubber or ceramic black middle piece.
Thanks again for any help.
Tim
   / X485 - Leaking oil at sensor to right of oil filter #4
Looks to be what you think. It is part no. M152192
They appear to be around $18
   / X485 - Leaking oil at sensor to right of oil filter #5
Tim
Did you fix the oil leak? Was it the sensor or gasket?
I am having the same problem on my X485.
   / X485 - Leaking oil at sensor to right of oil filter #6
I am having this same leaking problem on my 425 AWS. Before I buy the part, is there a fix short of getting a new part, like an o ring or something?
Thank you
   / X485 - Leaking oil at sensor to right of oil filter #7
Thank you
After having the same leak, I recommend replacing the sender. Realize this is a small leak but replacement of the sensor is the best solution.
Toro 880 Procore (A55758)
Toro 880 Procore...
VINTAGE GAS PUMP (A58374)
VINTAGE GAS PUMP...
(2) AIR OVER HYD JACKS (A58374)
(2) AIR OVER HYD...
LOT: Uline 72" Rolling Staircase, 6' Fiberglass Stepladder (A59076)
LOT: Uline 72"...
2018 Cadillac Armbruster 70IN Limo - 43,279 Miles, Professional Coachwork, Clean Executive Vehicle (A56435)
2018 Cadillac...
Portable Restroom (A54865)
Portable Restroom...
