Ranger repairs
/ Ranger repairs #1
Capricious
Eastern Missouri
Mitsubishi MT160D
My tow vehicle is a 2002 Ford Ranger, 3.0 V6, auto, long bed. The book says it will tow about 4,000 lbs. I use it and a single axle utility trailer to haul a walk-behind brush mower, old sears garden tractor and a Mitsubishi 16 hp diesel tractor (not all at the same time). Max. load, according to a truck scale, is about 2,600 lbs for the loaded trailer.
Back on Jan 15 I was driving on the highway and traffic stopped, and I stopped, but the guy behind me did not stop. Hit me hard and pushed me into the car in front of me. Some fairly good damage to the front:
However the main damage was to the rear:
The combination of bumper and receiver hitch was too solid to bend much, so the frame rails buckled right behind the rear spring hangers for the leaf springs. (2) body shops said the truck was essentially 'totaled," as the frame would need to be replaced.
The truck was still drivable and I continued to drive it, but I could not longer tow a trailer, which put me in a bind as I have some land to maintain, in addition to mowing about 1 1/2 acres for a non-profit.
Yes, I should see some money out of this incident, but I will not be seeing it any time a soon, as I was hit by a federal government vehicle, a DEA car. Until you have been hit by a government vehicle, and dealt with the Federal Tort Claims Act, you have no idea what the word "hassle" means. I expect to see some money maybe in August or Sept.
In the mean time, I have decided to repair the old Ranger to the extent that I can tow a trailer with it, to get me through the summer. Sometime, hopefully after the first of the year, I intend to replace it with a new truck, probably a 1/2 ton.
/ Ranger repairs
In some respects I am lucky that it is a Ford Ranger. Since Rangers have a real bad reputation for frame rust, there are after market suppliers selling replacement pieces for the rears of the frame rails, which is usually where the worst of the rust damage is.
I ordered a set of these pieces off ebay but was a bit dsapointed when they arrived. they were advertised as having all the right holes drilled in the right places, but no mention was made of, and no photos showed, the large clearance "cut-outs" in the flanges of the channels:
These cut-outs are intended to fit around the riveted tabs of cross members. Evidently the people who make these pieces assume one has rusted-out channel webs, but that the flanges are still solid, and the plan is for these pieces to overlap the original frame rails and be fully welded all around. The problem, as you engineering types are aware, is that the flanges are where the strength of a channel is.
I considered returning the things, but then I would have to pay return shipping, no small amount for a couple heavy hunks of 11 ga. steel. I also considered taking the pieces to a metal shop and having them make me up a couple pieces of channel out of 11 ga to the same dimensions, and then returning the original pieces for credit, but that would have run into some money. I finally decided to use the pieces, but to weld 3/16" doublers onto both the top and bottom flanges. I cut some flat bar to length, 2 inch for the bottom flange and 2 1/2 inch for the top flange, marked the positions of the holes, drilled the holes in the flat bar, and then welded it all up. My welding is not of the highest quality, but since these things are welded almost all around, and also welded on the back-sides in the "cut-outs,' and since there are also bolts that pass through both the doublers and the original pieces I am confident the things will hold together:
/ Ranger repairs
What really kinda pi__ me off is the big cut-outs in the flanges that I did not want, yet the pieces did not have a rounded cut-out on the bottom flange that I did need. The lower flanges of the frame rails on the truck have rounded clearance "bends" to allow the spare tire to fit in between them:
...so I had to trim the lower flanges on the new pieces to fit around these bends in the lower flanges:
I took a cardboard template of the frame rails to lay-out these cuts, and got them pretty close to correct. Had to do a bit of grinding once I could actually try them in place.
Primed them and put them aside:
/ Ranger repairs
Previously, I had fabricated a lifting boom for the 3-point on the little Mitsubishi tractor:
http://www.tractorbynet.com/forums/build-yourself/333128-3-point-hitch-lifiting-boom.html
I planned to use this to remove the bed from the Ranger. Yes, if you have one or two big guys to help you, lifting the bed off a Ranger is no big deal, but I have no one to help me, so I do everything by myself.
Left the bed hanging overnight; the lift did not "leak-down" at all:
/ Ranger repairs
Cutting off the frame ends with angle grinder & cut-off wheel:
Jacked-up the rear of the frame to remove weight from the leaf springs and unbolted the rearward spring hangers:
The spring hangers had been replaced about 2 years ago (orignals had rusted paper-thin) so removing them was pretty easy.
Fitting the replacement pieces for final trimming and additional hole drilling:
Grinding the heads off rivets, so that the cross member can be attached to the new frame pieces with bolts:
All bolts utilized are new; either metric M10, grade 10.9, flange heads on bolts and nuts, and self-locking nuts ( same as original); or SAE grade 8 including nuts & washers.
/ Ranger repairs
Done.
For those that care, no welding to original frame- new pieces are bolted only. Welding on new pieces was done with 100 amps ( top setting on my old 240 volt AC welder) 3/32 6013
Note that the spring hangers are bolted through new pieces and into original frame rails- suspension does not rely on the new pieces; just the hitch. Used new hardware to mount the hitch (grade 8) as the hitch took a real hit and I did not trust the old bolts ( which were grade 5).
Minimum (7) bolts holding each new piece on, not including bolts into cross member.
I drilled (2) new holes in each frame web- no new holes in the flanges (that's a no-no, I understand).
/ Ranger repairs #10
Outstanding work! It looks like it will be better than before.
I admire your skill in metal working and am glad the Ranger didn't go to the junk yard.
I bought aftermarket chrome bumpers for a Ranger once due to the old ones rusting out. I think I only paid about 150.00 each and they fit perfectly.
/ Ranger repairs
I'm no steel worker / fabricator; I'm just a hack.
But I decided that I needed to get one more year out of this truck. The "big name" body shops would not touch it unless they could put it back to factory specs, and the only way to do that was to replace the whole frame ( replacement factory frame sections are available for some trucks, but not this one.)
Some shops that deal with hot rods and the like would tackle it, but not for free (obviously).
So I decided to do it myself. I spent hours researching Ranger frame repairs on the internet, and what other people had done. Branched off into frame repairs of other brands of pickups, and even frame repairs/modifications on "big" trucks.
Learned what I could and could not get away with. For example, you can usually drill holes in the web (vertical section) of a frame channel, but there are restrictions. Drilling the flanges (horizontal places) is not advisable. Lots of controversy on frame welding; where you can weld, what you can weld, how you weld it, how you reinforce the weld.
I considered the issues of having inflexible new pieces fastened to flexible existing pieces. I found that replacing rivets with bolts is no big issue, assuming the correct bolts. And so forth.
I will obviously keep an eye on things, and re-torque all the bolts in the near future, but I am confident the thing will hold together.
EDITED TO ADD: Also, a bit of controversy on grade 8 bolts vs. grade 5. There are those that represent that grade 5 is better because it will 'stretch" before breaking, while grade 8 is "brittle" and will break without stretching at all, while there are others that say that the grade 5's will stretch and break long before the grade 8's reach their breaking point.
I went with grade 8, or the metric equivalent of 10.9 and I replaced all bolts I removed with new ones of similar or higher grade.
/ Ranger repairs #12
Never go cheap on fasteners.
I wouldn't call grade 8's "brittle".
The surrounding material will yield before the fasteners break.
/ Ranger repairs
Closing out this thread.
Sold the Ranger in October of 2015.
The DEA / Justice Department finally decided to settle with me for the amount of the lower of the (2) damage estimates that I had provided them. The settlement letter
was dated August 24, 2015. Of course, they did not even look at the case until the beginning of August. The Federal Tort Claims Act gives them 6 months to consider
the claim, and they took darn near every day of that 6 months before beginning to talk settlement.
As of today, Feb 22 2016, I see where the money has FINALLY been deposited into my bank account.
13 months and 7 days from accident to pay-off. Who says the federal government is dysfunctional?
I was literally within a few days of filing suit in Federal District Court over this matter pro se (meaning, with no lawyer). I had my civil complaint prepared.
Oh, I would like to thank all of you who pay federal taxes. Between the government pay out, and what I sold the truck for, I figure I ended up
with somewhere around $1,000.00 to $1,500.00 more that it would have sold for in undamaged condition. I just had to wait FOREVER to get it.
This is your government at work.
/ Ranger repairs #14
Closing out this thread. Sold the Ranger in October of 2015. The DEA / Justice Department finally decided to settle with me for the amount of the lower of the (2) damage estimates that I had provided them. The settlement letter was dated August 24, 2015. Of course, they did not even look at the case until the beginning of August. The Federal Tort Claims Act gives them 6 months to consider the claim, and they took darn near every day of that 6 months before beginning to talk settlement. As of today, Feb 22 2016, I see where the money has FINALLY been deposited into my bank account. 13 months and 7 days from accident to pay-off. Who says the federal government is dysfunctional? I was literally within a few days of filing suit in Federal District Court over this matter pro se (meaning, with no lawyer). I had my civil complaint prepared. Oh, I would like to thank all of you who pay federal taxes. Between the government pay out, and what I sold the truck for, I figure I ended up with somewhere around $1,000.00 to $1,500.00 more that it would have sold for in undamaged condition. I just had to wait FOREVER to get it. This is your government at work.
We need to vote smart this coming election to clean some of this up.
Chris
/ Ranger repairs #15
Brace yourself! Now you are gonna have to pay income tax on the extra $$. :)
/ Ranger repairs
Not really. The total recovery is only slightly higher than NADA "clean retail" [the highest value I could find online] so it would be a tough call to say there
was any taxable profit in it.
If it was well over any "book" value then there might be an issue.
2019 CATERPILLAR M316F MOBILE EXCAVATOR (A63276)
2019 CATERPILLAR...
John Deere 12in Channel Bucket w/ Teeth Excavator Attachment (A64194)
John Deere 12in...
Lonestar Panel 24ft. Free Standing Panel with Feed Bunk (A65640)
Lonestar Panel...
2016 CHEVROLET SILVERADO 3500HD DUALLY (A65643)
2016 CHEVROLET...
Mini Universal Root Rake (A65640)
Mini Universal...
2009 Chevrolet Silverado 1500 4x4 Ext. Cab Pickup Truck (A64556)
2009 Chevrolet...
