Kioti timer glow plugs
/ Kioti timer glow plugs #1
Whaler
Qc canada
Kioti dk45
Light stays on after engine is running,any danger to plugs or other things,can unplug relay?
/ Kioti timer glow plugs #2
How long does it stay on?
/ Kioti timer glow plugs #3
Depending on how cold it is, mine may come back on for another 5-8 seconds after engine starts which is normal. So as Murph asked, how long?
/ Kioti timer glow plugs #4
On a cold engine, glow plugs are supposed to remain powered for several seconds (even a minute) after the engine starts. This "after glow" allows the engine to run much smoother until the pre-chambers heat up. The glow light on the instrument panel is just an indication for the operator. For example, when the light goes out (on cold start) the glow plugs are still powered. On my tractor, the light does not come back on after start, but there are probably several versions of glow controllers that may work differently, as far as the light is concerned. As long as power to the glow plugs shuts off within a couple minutes after start, that's how it's supposed to work.
/ Kioti timer glow plugs #6
Mine will stay on for at least 20 to 30 seconds on a cold day.
/ Kioti timer glow plugs #7
When mine was new the timer stayed on as it was faulty. It should not remain on for more than a few seconds once the engine is running. Mine actually flattened the battery one night as I didn't realize it was stuck on.
Prolonged use can shorten the life of your injectors. Dealer replaced the Glow Plug Timer relay and no harm done.
/ Kioti timer glow plugs #10
I need to make one of those soon.
I have decided it is a very worth while addition. Very low cost, and allows you to keep an eye on the battery trends.
/ Kioti timer glow plugs #11
I think it is a very wise addition.
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2016 Honda Pioneer5 1000 (A62613)
2016 Honda...
2025 8in Channel Tooth Bucket Mini Excavator Attachment (A64553)
2025 8in Channel...
STIHL HT250 POLE SAW (A64276)
STIHL HT250 POLE...
2021 Sany SMG 200C-8 Motor Grader (A62679)
2021 Sany SMG...
Toro Groundmaster 580-D Rotary Mower (A66285)
Toro Groundmaster...
