free straight line smart phone app
   / free straight line smart phone app #1
tony45
Member
west milton,ohio
iseki ts2205
I plant one acre sweet corn with a one row planter,starting the first row is some times time consuming, is there a free app for smart phone to at least start the first row, I could mount phone on tractor to follow straight line, Thanks tony
   / free straight line smart phone app #2
Ever try just putting in a string line to follow?
   / free straight line smart phone app #3
That's what the hood ornaments were for on tractors years ago. Maybe you could find one you like at a junkyard and bolt it on. When using it, sight over the top of it to the spot you want the row to end and drive toward it without moving your head or blinking to much.
   / free straight line smart phone app #4
The smart phone uses GPS to locate itself, which is only accurate to 20 feet or so, which isn't enough for your purposes.
There are technologies that can locate with a couple of inches but they are thousands of dollars.
thanks gary and bigtiller used tobacco laths for many years as far as looking back I wired in a motorcycle horn and a limit switch on the cover wheel to let me know when the planter is planting, don"t have to look back just hear the horn every revulation of the cover wheel, when don"t hear beep know cover wheel is jamed,or sliding.
   / free straight line smart phone app #7
Not GPS based but a compass app might do. Or just get an old fashioned compass. Just be sure to account for metal mass.
well went and got a smart phone bracket at walmart 19.00+tax and compass for samson phone app, will try to go out tomorrow or sat. and mount it on hood of tractor,rows run north and south,will run in grass along field and see how straight I can make wheel tracks Thanks for input, Tony
   / free straight line smart phone app #9
How about if you mount one of those Laser pointers that they use to blind pilots in airplanes .If you mount it on your tractor and have a marker you should be able to hit the marker with it and drive to the marker keeping the pointer on the marker giving a straight row .I'm not sure how your phone app is supposed to work but even with auto steer you don't get a perfect straight line if you are using a guide bar to give you guidance for your line .
BOX OF (2) GENUINE MOPAR SIDE STEPS (A57192)
BOX OF (2) GENUINE...
UNUSED IRMC HIGH END ELECTRIC MASSAGE CHAIR (A57193)
UNUSED IRMC HIGH...
Adams 6 Ton Hydraulic Lime Spreader (A57024)
Adams 6 Ton...
2013 Ford Escape SUV (A55853)
2013 Ford Escape...
2025 Spirit Electric Scooter (A55853)
2025 Spirit...
202476 (A54757)
202476 (A54757)
