Modify Max 22 HSD
/ Modify Max 22 HSD #1
tngw1500se
Member
Oliver Springs
2013 Max 22
Has anyone every modified their Max 22 HSD so there are foot controls for forward and reverse on the left side? I can't work my brakes independently unless I have the HSD locked in forward. I'd like to be able to use the brake on one side or the other, while pressing the forward pedal. It's a problem in tight spots. Am I missing something or does Mahindra think I have two right legs? I hardly every need the clutch so my left leg could work the forward and reverse pedal.
/ Modify Max 22 HSD #2
Mahindra isn't the only tractor co that thinks we have 2 right legs.:confused2:
/ Modify Max 22 HSD #3
It may be easier to move the brakes to the left, and leave the hydro control on the right. They are likely cable operated, so you'd just need to put in your own pedals and run the cable lines. Not sure if it's be worth the effort, but I guess it depends how often you require the split brakes in tight quarters.
My 3550 has brakes on the left. That makes no sense to have split brakes on the same side as the hydro controls.
/ Modify Max 22 HSD
The brakes take a lot more force to push than the hydro pedal does so I think making another way to push the hydro pedal is the way to go. I'd really like it if I could operate the hydro from the seat when flipped around backwards operating the backhoe. Sometimes I want to move farther than I want to use the backhoe to push the tractor forward. I can reach behind and steer but I can't reach the hydro pedal.
/ Modify Max 22 HSD #6
Your not supposed to steer with the brakes on an HST tractor. Thats why the pedals are configured the way they are.:thumbsup:
/ Modify Max 22 HSD #7
Why would hst make any difference on the desire to use split brakes for maneuverability?
/ Modify Max 22 HSD #8
Well thats what they teach us at service school. The question always comes up about the poor location of the brake pedals. The standard answer from the instructors is there not to be used for steering. BUT, I just looked in the MAX op man and it says for use in turning???? Who knows!!:confused3:
/ Modify Max 22 HSD #9
They are on the left for my 3550 hst. Maybe they don't think the max needs the extra maneuverability, but the larger tractors might?
/ Modify Max 22 HSD #10
Why are you needing brakes while going forward in tight spots? trying to force steer it?
/ Modify Max 22 HSD #11
My 3016 has the brakes and the treadle on the right and it's virtually impossible to use the pedals for individual braking.
With my old Ferguson, I used the individual brakes quite often, especially when plowing snow. One wheel would spin and I'd apply the brake to that wheel, in effect giving the same effect as a differential lock. With the tube type fel sticking so far out, it would take a lot of room to turn it and when in the snow, I would lock one wheel to turn it in it's own length, more or less.
I initially was upset that I couldn't use the rear brakes individually, or the brakes at all, except for parking.. But after having it for over a year now and having gone thru two winters, one a real bugger, I found that the tractor turns in such a tight circle naturally, and since I do have a differential lock now, I don't really miss not being able to control the rears individually.
It is dumb placing the brake pedal(s) where they are but I'm betting you won't mind after using it for a while.
/ Modify Max 22 HSD #14
I understand I just never have had to mess with frozen ground lol. Use to do the same with 2wd tractors moving dirt
HYD, TRANSPORT WHEELS, PIN PULL, HI1100T202540981 (A62130)
HYD, TRANSPORT...
2008 Ford F-150 Ext. Cab Pickup Truck (A61568)
2008 Ford F-150...
43024 (A59228)
43024 (A59228)
2021 Ford F350 XL (A57148)
2021 Ford F350 XL...
2017 International Prostar 122 Day Cab (A62613)
2017 International...
TEST YOUR BID BUTTON! (A62129)
TEST YOUR BID...
