Kubota HP needed?
/ Kubota HP needed? #21
Having spend a whole day running a tractor mowing I would not want to use hydro as your leg will be tired. Also working on hills you will be losing a lot of HP to hydro on the hills. If your spending 100% on loader work hyrdo is great, field work power shift(gst) or gear.
I see what you mean. I will point out that most hydrostatic tractors nowadays have cruise control. Both of mine do (all three if you count the riding mower). To me, this eliminates the sore leg problem. I'm with you though, that I wouldn't want to mow all day on a hydro tractor without cruise. Regarding HP loss, I see what you mean. Personally, in my mind the HST is just so convenient that whatever losses it gives up in efficiency (mostly heat) are offset by the ease of turning, backing up, and changing gears. It's definitely a tradeoff, though and I see your point. Thanks for your explanation.
/ Kubota HP needed? #22
If your primary use will be brush hogging fields, my vote is for gear. However if you will be doing some loader work and rear implement work that may require some back and forth, a great compromise is HST with cruise control. I have had both and find the HST to be much better for the work I do. Like you, my biggest task is brush hogging a couple fields twice a year. I would not go back to a gear drive now having experienced both. Good luck! BTW, I run a 5 foot brush hog on my L3901 and am very confident it could run a larger one without any issue.
/ Kubota HP needed? #23
As mentioned, most now have cruise control. I've spent all day mowing with HST as well as gear and on our hill farm, I use three gears with our M8540, but can leave my 5740 in medium all day.
I grew up using gears and have more geared than HST machines, but I sure like them and am beginning to spend more time on the HST than gears.
/ Kubota HP needed? #24
Different opinions. I love hydro for mowing and bush hogging. The ability to change speed due to thickness of material being cut, ability to change speed as you get close to objects you don't want to hit, ability to quickly go from forward to reverse. The Grand L's have cruise control, so you leg never gets tired ;) In fact, the cruse control lever is like a big boat throttle, so you can make speed changes with that and not the pedal. Philip.
/ Kubota HP needed? #25
Yep, I use it almost as much as my pedal and really handy when turned around and going up and down on short steep inclines, pedal for reverse and cruise to come out, very easy with smooth transitions, no need to move your foot.
/ Kubota HP needed? #26
I think the MXs and basic Ls have 2 positions that you achieve by swapping wheels side to side. We're talking about R4s here. R1s will have multiple positions achieved by swapping side to side, changing the dish of the wheel, and how it bolts to the rim, regardless of the model. The Grand L series has R4s that can be adjusted to multiple positions similar to how R1s work.
You can adjust the dish on my MX as well, not sure if that is a new option (R4s).
ETA: already covered I just hadn't caught up.
/ Kubota HP needed?
Also FWIW, I regularly run a 6' brush hog through stuff I'd have a hard time walking through with out any bog down and hills appear to make no difference.
Thanks. This is the info I am lookin for. :). I want that power to eat stuff down and keep on going. I am flexible on the width and the hydro vs gear. I am used to shifting gears so that does not bother me. I had not thought about the cruise control, so that is something to look for. I think I will take whatever is a good deal as I normally only put 40-50 hours a year on my current 30pto hp Ford. I see a lot of 30 hp Kubotas for sale locally with very low hours, but I thought they would be no better than what I has as far as hp. The 40-45 pto hp machines in any flavor seem to be very limited except for new or used up. I suppose those machines are the sweet spot in power and size. Information from experienced users are gold as I now am confident on the size I need. Thanks
/ Kubota HP needed? #28
Go with a gear shift not a hydro on that hill as your will be in low range mowing a hill like that. We have a M5400 on a large 7' brushhog and really should have gotten a 6' but it is similar to landpride Rcf3672 a real heavy cutter. Look at a mx or grand l with gst transmission.
And get R1 tires
Yup for sure
I run a 6' bush hog behind my L3940, would not want to go with any less horsepower or any less weight. Most of the time the hp is fine to run a decent speed, occasionally have to slow down if weeds get thick or tall. I do not run front weights or FEL when I bush hog, so the L3940 weight is about the minimum I would want to be at. Philip.
I wouldn't ever consider (again) any hydro tractor with less than 60hp. You right foot's gonna be some sore with that hydro pedal. You'll wish you mowed it with a sickle.
Regards, Fred
/ Kubota HP needed? #29
Regards, Fred
I have had my L3940 hydro since 2009, no regrets, would do it again, never had a sore right foot. Use the cruise control... I own both gear and hydro tractors, when it comes to mowing, and almost any other task (minus some ground engaging work), hydrostatic transmission is the way to go. Philip.
/ Kubota HP needed? #30
Thanks. This is the info I am lookin for. :). I want that power to eat stuff down and keep on going. I am flexible on the width and the hydro vs gear. I am used to shifting gears so that does not bother me. I had not thought about the cruise control, so that is something to look for. I think I will take whatever is a good deal...
If value for money is important "good deal" and you are flexible gear vs hydro. It might be good to compare what you can get in an HST vs gear for the amount of money you're willing to spend on this.
I looked at a 40hp hydro before buying my 45hp gear. The 40hp hydro cost $3000 more and the engine felt like a dog compared to the 45hp gear. I went with the 45hp gear (with power reverser). I think those who are saying go for a GST are right on the money. Just not too many used GST tractors out there when looking used. A synchronized gear with power reverser is more common on the used market and you will be able to get more power for the $.
People seem to overlook that it isn't just the difference in power loss between gear and hydro with the same engine. It's power loss plus the fact that with gear you can go up an engine size of two for the same price! So yes, that HST may be convenient changing speeds for differing conditions, but with a larger engine and gear you might not have to change gears unless you want to go faster on the easy parts than the HST ever could.
/ Kubota HP needed? #31
One of the neighbors here just traded a 2012 L3940 with the glide shift transmission. He was never pleased with the power but loved the transmission for brush hogging and that's about all he ever did with it.
I've always been a believer that 10 years or more down the road when the hydro craps out that gear transmission will still be working and cheaper to fix. Been wrong before, like when I bought my L3940 that I still hate.
Fred
/ Kubota HP needed? #32
Get rid of it ?!? I would never live with something I hated so much, life is too short... Philip.
/ Kubota HP needed? #33
/ Kubota HP needed? #34
I got my 6' Landpride cutter for an additional 10% discount beyond my dealer's normal discount because the customer who bought it or his 40 HP tractor found he did not have enough power and had to downsize to a 5' leaving the dealer with this slightly used 6' late in the year. It's properly sized for my L5740. As for hydro, for our use not a lot of horsepower is used for ground drive - most goes into the cutter. One thing - we don't use it for easy cutting jobs. We cut back growth around our grain fields, clear and widen shooting zones, trails through the woods, etc. used to be done with a M-F 135 but the gear shift sucks in this type of work. Clipping a pasture okay but varying load and direction makes the difference for us.
/ Kubota HP needed?
Fred
Ha ha. That is what I thought, but I did not want to start a fight. But since you threw the first punch I will join in. The old gear transmission has been around for a long time and is proven. That (gears) are what I am leaning towards. Hydro's :confused: I know my grandpa would be ready to get a new dozen and CAT would send out a rep with the newest hydro dozen and he would send it back with them that afternoon after the test day was over as it did not compare to his gear driven one. Eventually he had to have CAT rebuild his old dozer, twice.
/ Kubota HP needed? #36
I've said this before, but I'll say it again here. This gear argument is a red herring. One can say "geared transmissions are simpler than hydro transmissions". This is true. They may be more durable as well. But this is in reference to a straight, crash box manual transmission. You can't say geared transmissions are simpler and more durable and then recommend a glide-shift transmission, or anything with a power-reverser. These are not any simpler or more durable than a hydrostatic transmission. The only advantage that they have over a hydro is that they're more efficient at putting power to the wheels.
Every type of transmission has it's proper application, but I for one wouldn't want to mow all day or do any loader work with a straight crash box just because it might be a little more durable.
/ Kubota HP needed? #37
I wonder how many of us will ever put enough hours one a tractor to need a transmission rebuild regardless of transmission type?
/ Kubota HP needed? #38
Very few for sure assuming a proven quality brand.
/ Kubota HP needed? #39
Do a search for lesser known brands with bad hydros compared to gear. Most are Asian brands and un-affordable once they break years down the road or no parts available, rendering your investment unusable.
Fred
/ Kubota HP needed? #40
Fred
OK, so what about the 'lesser know brands'? Who cares? That is why I bought Kubota. In his 1st post he said he decided to buy Orange and he is posting in the Kubota forum. Why bring that up and confuse him. To my knowledge from other Kubota owners, my experience, and from reading this board, the Kubota HST is reliable. I really like GladeHounds post, how many of us are going to put that many hours on a tractor that we will need a trans rebuild, no matter which type of Kubota trans we get? Great point. To OP, make sure you drive both, then be happy with your decision. If not, trade for something else. Good luck! Philip.
(INOP) 2017 FORD F550 XL SERVICE TRUCK (A62130)
(INOP) 2017 FORD...
FRONTIER RB2072-72" SCRAPE BLADE (A62130)
FRONTIER...
Zero Turn Mower (A59231)
Zero Turn Mower...
2014 KENWORTH T370 ROAD TRACTOR (A62130)
2014 KENWORTH T370...
FRESHLY REFURBISHED! 2016 KBH Fertilizer Tender Trailer - Isuzu Diesel (A63118)
FRESHLY...
1997 Take 3 Auto Transport Trailer Trailer, VIN # 1C9TT5036VB409167 (A61165)
1997 Take 3 Auto...
