Kubota HP needed?
/ Kubota HP needed? #1
pburchett
Member
South Central Kentucky
Ford 640 & Kubota MX5200HST
Looking to buy a tractor and have decided upon an orange one. Was wondering how much HP I need. The tractor I need will have to be about 62-66 inches wide, category I hitch, 4x4, front loader, able to run a 6 ft bush hog. Hydrostatic would be ok but not necessary. The most demanding use will be for cutting an overgrown field once a year that is too steep to go side to side so it's has to be on the up and down to avoid turning over. Here is my HP thinking, 30 for the bush hog, 5 for the 4x4, 5 for the hydrostatic and 5 more HP for the steep terrain. So.....Would a 45 pto HP tractor be enough or overkill. I see a lot of 28-30 pto hp tractors for sale but I do not think this would be enough power for my use. Any suggestions form experienced orange users?
/ Kubota HP needed? #2
Why that width? A 45 Hp PTO tractor would probably be wider
For a 6' rotary cutter going uphill I think a
456686d1455218736-kubota-hp-needed-8x6sam_0797-jpg
40 plus PTO HP
456687d1455218741-kubota-hp-needed-8x6-g4-using-forks-jpg
tractor would do well.
Set the wheels wide and it's over 80". Set them narrow and I can get down to 78", to fit easily on my trailer.
/ Kubota HP needed? #3
I have heard the rule of thumb is 5hp per foot of width of mower. A little extra would be easier on the tractor.
/ Kubota HP needed?
Trying to keep the bush hog wider than the tractor so it clears out the tire tracks and so it will fit on a trailer
/ Kubota HP needed? #5
Lots of Kubotas in the 40-45 range and I believe it will spin a 6' cutter without much issue, you can always slow down a bit or not make a full cut if you do it only once a year, I prefer to mow a bit more often, but it's not unusual to do it once a year. My 5030 was rated for a 7' cutter and easily went through some really gnarly stuff over my cab.
/ Kubota HP needed? #6
You could "get by" with something around 30 pto hp but it would be worked pretty hard in heavy mowing so you'd need to slow down and/or take narrower passes. As others say, a machine with 40 or more pto hp will have a nice reserve of power with a 6 ft. cutter and will handle about anything you can drive over, on any grade that's safe to climb.
/ Kubota HP needed? #7
In the Kubota flavor, any of the MXs, an L4701, or an L4060 or larger Grand L would do the job. You can probably spend anywhere from $30-60k on one of these machines off the lot. As Newbury points out, there are used options as well.
/ Kubota HP needed? #8
My L3200 has 32hp & is 60" wide with non adjustable R4 tires. It runs a 5' rotary cutter fine. The extra couple of HP on a L3800 (or now a L3901) might be worth it for a 6' cutter. I think they could lift a heavier 6' without to much problems. Going up to a 4 thousand series might be a bit better though.
/ Kubota HP needed? #9
As you shop, inquire which Kubota models are designed by the factory to have the rear wheels spaced wider. The Grand L's, for instance, can all have the rear tread width increased with the standard tires. The rear tread width on my L3560 can be adjusted from 47.2" width to 58.3" width, in four increments, by changing tires positions, no spacers or other add-on required.
The Operator's Manual covers adjusting tread widths.
Front tread width is not adjustable with 4-WD.
Nothing will add greater stability on your hills than increasing tread width.
Wider tires assist. Loaded rear tires assist. Greater tractor weight assists.
HST would be my choice for use on your hill.
/ Kubota HP needed? #10
FYI: MX series with r4s can definitely be widened with stock wheels by flipping.
/ Kubota HP needed? #11
Go with a gear shift not a hydro on that hill as your will be in low range mowing a hill like that. We have a M5400 on a large 7' brushhog and really should have gotten a 6' but it is similar to landpride Rcf3672 a real heavy cutter. Look at a mx or grand l with gst transmission.
And get R1 tires
/ Kubota HP needed? #12
I run a 6' bush hog behind my L3940, would not want to go with any less horsepower or any less weight. Most of the time the hp is fine to run a decent speed, occasionally have to slow down if weeds get thick or tall. I do not run front weights or FEL when I bush hog, so the L3940 weight is about the minimum I would want to be at. Philip.
/ Kubota HP needed? #13
And get R1 tires
Why gear shift? Your reason: "you will be in low range mowing a hill like that" doesn't favor gear or hydro. For me, having a hydrostatic machine makes mowing super easy and efficient because I can always be in the perfect gear to match changing ground conditions and sward density. A geared machine may have one gear that's just a touch too fast forcing you to use a gear that's considerably slower than necessary.
/ Kubota HP needed? #14
And get R1 tires
/ Kubota HP needed? #15
The base L's 00 & 01s R4s can't be adjusted, unlike the Grands & apparently MXes. Duno about the Ms.
/ Kubota HP needed? #16
I think the MXs and basic Ls have 2 positions that you achieve by swapping wheels side to side. We're talking about R4s here. R1s will have multiple positions achieved by swapping side to side, changing the dish of the wheel, and how it bolts to the rim, regardless of the model. The Grand L series has R4s that can be adjusted to multiple positions similar to how R1s work.
/ Kubota HP needed? #17
FWIW: At least for the MX4800 and MX5200 I can say for certain there are 4 wheel widths for R1 AND R4 (only 2 with turfs). I suspect all the MX models are the same.
Not sure this matters to the OP but just wanted correct info out there.
Attached is from the manual.
/ Kubota HP needed? #18
Also FWIW, I regularly run a 6' brush hog through stuff I'd have a hard time walking through with out any bog down and hills appear to make no difference.
/ Kubota HP needed? #19
Oh, good to know. I knew they had at least two positions for R4s, but I didn't know they had 4. That's a nice feature.
/ Kubota HP needed? #20
Having spend a whole day running a tractor mowing I would not want to use hydro as your leg will be tired. Also working on hills you will be losing a lot of HP to hydro on the hills. If your spending 100% on loader work hyrdo is great, field work power shift(gst) or gear.
2023 Stearling Trailer (A60352)
2023 Stearling...
UNUSED KJ 20' BI-PARTING GALVANIZED GATE (A62131)
UNUSED KJ 20'...
JOHN DEERE 635F 35' HYDROFLEX PLATFORM HEADER (A62130)
JOHN DEERE 635F...
2012 Sunflower 5035-28 Cultivator (A63116)
2012 Sunflower...
1986 Eager Beaver B9D0W 20ft. 11 Ton Tri Axle Dovetail Tag A Long Tailer (A61568)
1986 Eager Beaver...
2016 CHEVROLVET SILVERADO 2500 TRUCK (A62130)
2016 CHEVROLVET...
