Tiller Bush Hog RT60G tiller any owners out there?
   / Bush Hog RT60G tiller any owners out there? #1
Buty
Canton, GA
Kubota L3200
This seems to be a fairly new tiller and I was wondering if anyone has any experience with them. I can't seem to find a manual on the web, only brochures and other literature. Looks comparable to King Kutter Professional, Tayor Way, and Tarter as far as the weight goes anyway. From what I see, it sells for between mid $1,900.00 to $2,200. Any thoughts?
   / Bush Hog RT60G tiller any owners out there? #2
Our Tarter 60 inch is geardrive and will operate in forward and reverse rotation. Delivered price is $1842 to a Truck Terminal or Commercial Business in Georgia. Add $50 for residential/farm delivery. Ken Sweet
The Bush hog also operates in forward or reverse rotation. Also gear drive. I found one here in Georgia for $1750 plus tax. Will be picking one up tomorrow morning.
   / Bush Hog RT60G tiller any owners out there? #4
What is Georgia's sales tax rate? 6% here in Ky. Ken Sweet
Same here in Georgia 6%.
   / Bush Hog RT60G tiller any owners out there? #6
If I am reading the Bush Hog companies website correctly, you can get either forward or reverse, however, not both on the same machine as the Tarter brand features. The RT60-G or RT60-GR are 2 different machines. Ken Sweet
According to Bush Hog, the only difference in the two machines is that the RT60-GR is already set up as reverse and the RT60-G is set up as forward. To reverse either machine, you unbolt the main shaft and turn it 180 degrees, then flip the top gearbox. The reverse RT60-GR comes with the black front shield included. Both machines are pre-drilled for the shield. Does Tarter include the front shield?
1838 (A51248)
1838 (A51248)
2005 Mitsubishi Lancer ES Sedan (A54815)
2005 Mitsubishi...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A55852)
2014 Peterbilt 384...
2002 MACK CHU613 BOBTAIL VAC TRUCK (INOPERABLE) (A55745)
2002 MACK CHU613...
Ford Tractor (A50120)
2013 Nissan Rouge SUV (A53424)
2013 Nissan Rouge...
