TIG question (arc problems)
/ TIG question (arc problems)
Ground clamped was directly to the shiny SS part, should be good, but I will clean it further to eliminate that. The beltsander had sanded some steel recently & since the misbehavior is at the tungsten I'm thinking its' got steel contamination. The initial arc is OK for about one second, then it does the halo thing. So I suspect the steel bits on the surface are causing trouble as soon as the tungsten gets hotter than steel's melting temp. That's probably it. If not it was a good theory.
Will try the flapper disc that has done nothing but tungsten. I've learned why TIG welders have dedicated TIG grinding wheels...
#1) of course, the cleanliness.
but nobody ever says #2......
#2) you spend a LOT of time re-grinding the tungsten. It needs to be quick and easy. Even picking up the angle grinder, positioning it, then waiting for it to spin-down, and not setting it down where it will get contaminated, takes a lot of time when you have to do it so many times for one stinkin' little weld job.
This regulator is the one supplied with the Miller TIG kit. It worked fine before (apparently). Although I was a little surprised how fast I used up a 50CF bottle.
What difference would you expect betw. the two?
/ TIG question (arc problems) #14
Accuracy!
I had two shifts of welders splicing these 10-feet in diameter pipe just down river of the Bonneville dam. Running 1/16" dual shield. 100 % xray. I bought all regulators, the welders refused to use them, they wanted flow meters.
/ TIG question (arc problems) #15
"I was a little surprised how fast I used up a 50CF bottle" - if your settings are right, that bottle would only last 2 - 2-1/2 hours - if it was 'WAY shorter than that, you might have been looking at the RED setting scale (LPM) - although I doubt you would make that mistake, it might also explain the crappy arc :D
You ARE using straight Argon, right??? Steve
Also, on tungsten grinding SA forgot to warn you - you don't wanna run the drill more than its SLOWEST speed using the drill/grinder method, or you'll put a SPIRAL/CONCENTRIC pattern on the tungsten - that can REALLY mess with your mind...
I twirls the rod in my fingers. I get the point I want grinding it cross-ways on the angle grinder using a flapper disc. Then the last twirl is a slow 'polish' (possibly shinier than anything Steve has ever seen) and the very fine scratches are axial to the tip.
I think I figured out the "arc halo" problem. Going back to using my "ONLY TUNGSTEN" grinding disc did not solve the problem. It may help but it wasn't the problem.
When I first press the pedal, the gas flows forcefully, then it steadies at a lesser rate. So it's like the gas flow is too much at first, like it's doing a 'purge'. If I start the arc immediately after pressing the pedal, it has that Halo problem. If I wait for just about 1 second for the gas to slow down,
then do my :thumbsup: "LIFT arc" :thumbsup: :D
then the arc starts normally. What a relief. Not sure how that came up, maybe I was just welding faster! :D
456292d1454882109-tig-question-arc-problems-ssbarweld-jpg
Heres a stainless motorcycle protection bar 'repaired'. Man this TIG is fun stuff!
Well I guess it does!
I was probably just doing my :thumbsup: "LIFT arc" :thumbsup: :D too soon. Going off all half-cocked like some young feller! After I release the pedal the gas flows for a few seconds too.
/ TIG question (arc problems) #19
Most welders have a timer where you set the amount of time for pre flow, before the power comes on. And you can set the amount of time for post flow.
Not this welder, it's not much bigger than a welding helmet. It's all pre-set but I can change wire speed & voltage. I have to learn to work with the pre-sets.
2019 CATERPILLAR  XQ35 GENERATOR (A58214)
2019 CATERPILLAR...
48in Forks and Frame Skid Steer Attachment (A56857)
48in Forks and...
2015 Chevrolet Silverado 3500HD Knapheide Enclosed Service Truck (A59230)
2015 Chevrolet...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
2008 TEXAS BRAGG GOOSENECK FLATBED (A58214)
2008 TEXAS BRAGG...
