TIG question (arc problems)
/ TIG question (arc problems) #1
Sodo
Elite Member
Cascade Mtns of WA state
Kubota B-series & Mini Excavator
Was trying to weld some SS, 1/16" thick with the MultiMatic200 (with Miller TIG kit). Had an awful time getting an arc started. Sometimes it would just make a conical halo around the sharp cone-tip of the tungsten. And when I did get a real arc going, the arc seemed hotter than the 'settings' was difficult to control. Ground clamp was set directly to the work, and was clean I think. Never got anywhere. Any ideas?
/ TIG question (arc problems) #2
How are you grinding the tungsten?
What was the amperage?
How far away from the part were?
What machine and what all settings do you have available to adjust?
Tungsten ground (parallel) on a beltsander. Previously when all was working I was using a flapper disc. That's the only change I can think of.
I don't recall the amps, because the machine has a 1/16" (thickness) setting. It does display the amps for that setting but I don't remember. Will try again and pay attn. Not sure I can say how far away, was trying anything to get the arc started but generally from 0 to 1/16" away. Basically it acted like it was trying to arc anywhere OTHER than at the point.
/ TIG question (arc problems) #4
Sounds like a ground issue. I know you said it was clean/tight, but if I am picturing what you are describing correctly, it is exactly what happens when I forget to clamp the ground on.
/ TIG question (arc problems) #5
I'll bet it's the way you are sharpening the tungsten. Use a drill motor on a dedicated grinding wheel. Don't use the grinding wheel for anything but tungsten.
/ TIG question (arc problems) #6
If your ground is proper, it could be a shielding gas problem. Is it a new bottle? It may be contaminated. IF you have used the gas bottle previously with good results, check the fittings on the torch all the way from torch to bottle. A loose coupling will suck air inside the hose and mess with your arc and weld.
Hmmmmm. First welds offa fresh filled bottle. The valve was shrink-wrapped with the gas company's wrap.
I use these "CPC" gas fittings, always purge the short line off the regulator and hook them up with gas flowing. The other connector to the welder has a shutoff, it seals when disconnected and holds the gas in the line.
454652d1453594918-tig-question-arc-problems-cpc2-jpg
454651d1453594918-tig-question-arc-problems-cpc1-jpg
Not this time, its house current.
/ TIG question (arc problems) #10
Interesting... I got same genny as u and was stick welding with it yesterday on my Lincoln 210mp and it worked fine but arc behaved a little different...
My money's on post 5. Dedicated wheel...possible contamination if not..
Ground clamped was directly to the shiny SS part, should be good, but I will clean it further to eliminate that. The beltsander had sanded some steel recently & since the misbehavior is at the tungsten I'm thinking its' got steel contamination. The initial arc is OK for about one second, then it does the halo thing. So I suspect the steel bits on the surface are causing trouble as soon as the tungsten gets hotter than steel's melting temp. That's probably it. If not it was a good theory.
Will try the flapper disc that has done nothing but tungsten. I've learned why TIG welders have dedicated TIG grinding wheels...
#1) of course, the cleanliness.
but nobody ever says #2......
#2) you spend a LOT of time re-grinding the tungsten. It needs to be quick and easy. Even picking up the angle grinder, positioning it, then waiting for it to spin-down, and not setting it down where it will get contaminated, takes a lot of time when you have to do it so many times for one stinkin' little weld job.
This regulator is the one supplied with the Miller TIG kit. It worked fine before (apparently). Although I was a little surprised how fast I used up a 50CF bottle.
What difference would you expect betw. the two?
/ TIG question (arc problems) #14
Accuracy!
I had two shifts of welders splicing these 10-feet in diameter pipe just down river of the Bonneville dam. Running 1/16" dual shield. 100 % xray. I bought all regulators, the welders refused to use them, they wanted flow meters.
/ TIG question (arc problems) #15
"I was a little surprised how fast I used up a 50CF bottle" - if your settings are right, that bottle would only last 2 - 2-1/2 hours - if it was 'WAY shorter than that, you might have been looking at the RED setting scale (LPM) - although I doubt you would make that mistake, it might also explain the crappy arc :D
You ARE using straight Argon, right??? Steve
Also, on tungsten grinding SA forgot to warn you - you don't wanna run the drill more than its SLOWEST speed using the drill/grinder method, or you'll put a SPIRAL/CONCENTRIC pattern on the tungsten - that can REALLY mess with your mind...
I twirls the rod in my fingers. I get the point I want grinding it cross-ways on the angle grinder using a flapper disc. Then the last twirl is a slow 'polish' (possibly shinier than anything Steve has ever seen) and the very fine scratches are axial to the tip.
I think I figured out the "arc halo" problem. Going back to using my "ONLY TUNGSTEN" grinding disc did not solve the problem. It may help but it wasn't the problem.
When I first press the pedal, the gas flows forcefully, then it steadies at a lesser rate. So it's like the gas flow is too much at first, like it's doing a 'purge'. If I start the arc immediately after pressing the pedal, it has that Halo problem. If I wait for just about 1 second for the gas to slow down,
then do my :thumbsup: "LIFT arc" :thumbsup: :D
then the arc starts normally. What a relief. Not sure how that came up, maybe I was just welding faster! :D
456292d1454882109-tig-question-arc-problems-ssbarweld-jpg
Heres a stainless motorcycle protection bar 'repaired'. Man this TIG is fun stuff!
Well I guess it does!
I was probably just doing my :thumbsup: "LIFT arc" :thumbsup: :D too soon. Going off all half-cocked like some young feller! After I release the pedal the gas flows for a few seconds too.
/ TIG question (arc problems) #19
Most welders have a timer where you set the amount of time for pre flow, before the power comes on. And you can set the amount of time for post flow.
Not this welder, it's not much bigger than a welding helmet. It's all pre-set but I can change wire speed & voltage. I have to learn to work with the pre-sets.
