Dentures anyone?
/ Dentures anyone? #1
QRTRHRS
Elite Member
The Bluegrass State
None at this time.
Thought I would start a thread about choppers or lack of, lol! First off, bad teeth run in my family, brushing, flossing, pro cleaning regardless. The major reconstructions I had done in 1973 and 1995/96 have been going bad. Last fall, one of my front teeth absessed. Both front teeth were part of a six tooth bridge (two intact, two missing, two intact). The other front tooth previously had a root canal and had basically turned to punk. So, I lost both front teeth.
Long story short, the seventeen teeth I have left just won't long term support more bridges/partials so I elected to get them all out. Like many people here in KY, I go to the UK School of Dentistry in Lexington, KY to let students work on me. (Reduced cost care, excellant care really)
Anyway, after plenty of discussion with the student working on me and the resident doctors, I am going to have two implants in my lower jaw to stabilize the lower plate. I have heard pro and con from others but no first hand experiances. Anyone have any input on the implants?
/ Dentures anyone? #2
They pulled all my uppers and I have an appliance up there.
They did a great fit and I don't even realize I have it in place.
For lower jaw I still have 7 good teeth with a partial that is mainly molars.
The fitting is so good that I eat whatever I want and can even enjoy corn on the cob.
Further more I do not use any adhesives either.
They totally dissuaded me from any implants or pins.
Believe it or not I am so accustomed to my appliances that I feel cold as the nerves seem to read thru the upper appliance.
They had to pull my 7 remaining uppers all in one sitting and I never even needed an aspirin for pain.
My upper was done in 2 stages with a 'temporary' that they placed the same day as they did the pulling.
I was lucky as my wife's insurance covered most of my upper appliance.
The balance was traded for some renovations in his home.
/ Dentures anyone? #3
From the title I thought you were selling.... ;)
I have one false tooth on a titanium rod implanted in my jaw. The rest are mine, although three are crowned. I've never had a lick (pardon the pun) of problems with the implant. I've had the crowns pull off on sticky foods several times.
Anyhow, my implant probably doesn't apply to your situation as there are no dentures being anchored to it. Good luck with your new smile! :D
/ Dentures anyone? #4
Just started the procedure yesterday by getting the impressions made. No implants. Had only 11 teeth remaining and broke two of them last week. All will be pulled and the plates installed in 2 1/2 weeks.
Noinsurance. I have a better than platinum plan through the AF but it doesn't cover dental. Total cost will be $2,000 but that is no a problem for me.
Harry K
/ Dentures anyone? #5
There is a huge difference between a full denture that just rests on the gums versus one that is supported by implants. The implant supported denture will not flop all over the place thereby giving you better chewing abilities, less chances of sore spots on the gums, and greatly superior confidence when talking.The only negative is expense. But, if the treatment estimate is within your budget, you should definitely pursue the implant supported denture. It will be very important for you to keep the implants really clean since poor oral hygiene can cause implants to fail. (If you haven't already guessed, I am a dentist.)
/ Dentures anyone? #6
I still have most of my original teeth... in a cigar box on a shelf in the garage!
mark
/ Dentures anyone? #7
I just have one implant, had it done 6 years ago. They are a little on the expensive side, but you will never regret doing it. 100% trouble free since day one.
/ Dentures anyone? #8
That is the reason I went with the 'no implant'. I am very poor at dental hygience - mostly the reason I only have 9 teeth left :)
Harry K
/ Dentures anyone? #9
Harry K
/ Dentures anyone? #10
I'm curious as to what ever happened to the story about using a laser for dental treatment? I remember an article years ago where a laser was touted that it would be the next "drill" for dentistry. Seemed like a big thing at the time but just sort of fizzled out? I've still got all my teeth at 60 (couple of crowns though). Floss every day and brush three times a day. When I go for annual cleanings twice a year, I usually wonder about what people did a hundred years ago or more. One of the neatest things that my dentist has is a machine that makes a crown while I'm just sitting there. Sticks this little do-dad in the mouth and takes a bunch of different angle pictures and somehow this contraption sends the info to his lab in the back. About an hour or so later he steps back there and magically appears with a crown that fits almost perfect. He usually has to adjust it slightly. Some kind of machine cuts it out. Truly a great time to be living with medical marvels and treatments.
/ Dentures anyone? #11
I'm sure 'concordriver' has a more informed, articulated response...but I know they have been using a laser to set filling material for quite a few years...just recently I have seen some advertising for some consumer available adhesives etc...that use a laser as catalyst...I'm curious about it...
/ Dentures anyone? #12
You sure that's a laser and not just UV light?
/ Dentures anyone? #13
I don't think they were ever going to use a laser for drilling, but I'll guess that the thing they stick in your mouth to take a picture of your tooth to make a crown is some form of laser scanner.
/ Dentures anyone? #14
Go figure.......my dad had all his teeth pulled at 35 due to constant problems.....wore dentures the rest of his life. Mom had lots of cavities and fillings so did my older brother. I have never had a cavity....have all my teeth except the front two I knocked out as a kid....those are capped. I brush but rarely floss. Just had my teeth cleaned last week......even the dentist doesn't understand it. Oh well.......that's the good news......the bad news.....both my knees are worn out........that's life.
/ Dentures anyone? #15
There are basically two types of dental lasers. The first type operates at a wavelength that is good for cutting soft tissues (gums) and the second type that operates at a wavelength that is good for cutting hard tissues (teeth). I hope to own a soft tissue laser some day...waiting for prices to come down. I don't see any major advantages of the hard tissue laser compared to the drill. The media often produces stories about new technologies that will revolutionize current methods. But, these stories are usually not realistic.
The digital scanners and in-office milling machines are pretty cool. I hope to own a digital scanner some day. It is a rapidly evolving field. The units get better and better each year and less expensive too. Right now the digital scanners go from $18K-$50K. I am not really interested in the in-office milling machines. My patients are not going to wait around my office for an extra hour to wait for their restorations to be milled. They would rather come back for another appointment. Also, the dental labs can mill a wider range of materials than an in-office milling machine can do. A combination digital scanner/in-office milling machine costs ~ $100K. I have found that some unethical dentists justify the expense of this equipment by doing unnecessary work. So, make sure you really need this type of treatment before you agree to it.
/ Dentures anyone? #16
" I hope to own a soft tissue laser some day...waiting for prices to come down. I don't see any major advantages of the hard tissue laser compared to the drill."
It seems the soft tissue laser would be advantageous to slow the bleeding of the soft tissue, when you have to slice and dice? I hate the sounds the "drill" makes, brings back the sounds of the old dentistry torture of way back when....lol. Has to be one of the most powerful stimulus response type of reactions on the planet....lol. Instantly tense up and freeze. :eek:
/ Dentures anyone?
On the lowers, I have my wisdon teeth and most of my front teeth save for one where the cap would not stay on after a root canal. Since I currently wear a partial on the bottom that is about shot after 20 years, I asked about another. I would need at least three new caps and one wisdom tooth and one front tooth are not the best hence the implants and full plate on the bottom.
On the top, I just do not have enough stable teeth left.
Not sure of the extraction costs yet but the implants are 675/each, plates 280 apiece. As I said when I started the post, I am going to the University of KY School of Dentistry so the costs are managable. The biggest drawback is time. It tends to drag out a bit because the students have their schedules as opposed to a practicing dentist. So far though, I have no complaints. The care has been excellant and everything is overseen by resident doctors.
/ Dentures anyone? #19
$675.00 is cheap for an implant.. I have several implants due to bad teeth.. 1 implant only lasted about 3 days ,and fell out..Doc says it happens sometimes.. Had to wait about 6 months to let the hole heal ,then tried it again at additional cost.. It stayed the 2nd time. They are $1500.00 a pop here.. Then $325.00 for the crown to go on the implant
UNUSED MOWER KING-AGT SAII100 (A64281)
UNUSED MOWER...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61573)
2022 Peterbilt 567...
2018 CAT 259D Skid Steer (A62613)
2018 CAT 259D Skid...
72in. Fork Extension (A61572)
72in. Fork...
2013 International DuraStar 4300 Ledwell 2,000 Gallon Water Truck (A61573)
2013 International...
2025 MB27 27in Mixing Bucket Mini Skid Steer Attachment (A61572)
2025 MB27 27in...
