Tire Selection What size R4's for Kubota L2350
   / What size R4's for Kubota L2350 #1
marketman62
Victoria, TX
Kubota
Just bought a used Kubota L2350 and it needs new rear tires. My soil is sand and heavy clay. No serious AG work. Mostly using it for general chores, shredding and maybe some small food plot work. I have a LOT of wesatche and mesquite with some serious thorns. R1's can make terrible ruts. I am thinking about going to R4's and I'd like thoughts/opinions and need to know the tire size. R1's are 11.2-24's rear and 7-16's front. Can't find how those size #'s translate to R4 size's. Ideas? Suggestions?
Thanks.
   / What size R4's for Kubota L2350 #2
You'll need to change the wheels to use the R4's. They are a much wider tire. Cost may become an issue for you then. I much prefer R4's over R1's, but I bought my tractor with them.
   / What size R4's for Kubota L2350 #3
If your L2350 is 2 WD you can use any pair of R4 tires and rims that will fit your tractor bolt pattern. If 4WD then you have to use tires compatible with the front and rear gear ratios. Here is a list from another brand tractor that uses the same Ag tires so the corresponding R3 and R4 tires combos should work for you. You will need to buy both rims and tires
Ag front: 7x16
Ag rear: 11.2x24
Lawn/turf front: 25x8.5-14
Lawn/turf rear: 13.6x16
Industrial front: 27x8.5-15
Industrial rear: 15x19.5
   / What size R4's for Kubota L2350 #4
Ag front: 7x16
Ag rear: 11.2x24
Do you know where to get the 13.6x16 turf tires or know of a compatable cross referenced one?
   / What size R4's for Kubota L2350 #5
Thank you for your response. This is what I have now Lawn/turf front: 25x8.5-14 Lawn/turf rear: 13.6x16 but it is hard to find the tires for the rear. I was wondering if someone else sells turf tires that have different numbers that would work on same turf rims! :)
2019 JOHN DEERE 317G SKID STEER (A51242)
2019 JOHN DEERE...
2011 INTERNATIONAL PROSTAR +122 6X4 DAYCAB ROAD TR (A51243)
2011 INTERNATIONAL...
2021 FREIGHTLINER CASCADIA SLEEPER TRUCK (A51219)
2021 FREIGHTLINER...
2015 Kia Sorento SUV (A50324)
2015 Kia Sorento...
2009 Freightliner Columbia 120  10-Speed, Mercedes MBE4000, 6x4 (A52128)
2009 Freightliner...
2017 Ford F-150 Ext. Cab Pickup Truck (A50323)
2017 Ford F-150...
