Lets discuss inverters......
/ Lets discuss inverters...... #1
5030
Rest in Peace
SE Michigan in the middle of nowhere
Kubota M9000 HDCC3 M9000 HDC
Don't have a clue where to stick this and I did a forum search and came up with 2,250 possible threads, problem is, of the ones I looked at, none were related to my question / issue...
I need to purchase a 12 volt to 110 volt inverter for my CPAP machine. I need it to use in my camper when I'm in the boonies. I have a portable inverter genny (Yamaha 2800I) but I don't want to run the genny at night, I prefer to run an inverter from the RV batteries (2 large deep cycle).
I think I need a pure sine wave inverter in as much as the CPAP machine is electronic and I'm thinking 1000 watt output should be plenty.
Can I run a 1000 watt inverter all night on 2 deep cycle batteries, no issue recharging, I'll just fire up the inverter genny but I want to sleep, not listen to an engine all night....
It's not a motorhome or a pull behind, it's a truck slide in camper, self contained. I use it for hunting and fishing.
Thoughts please....?
/ Lets discuss inverters...... #2
I use a c-pap, the blower portion is 12V DC, only the humidifier is 120 AC. The blower will run for days on a deep cycle battery, it's the humidifier that really sucks the juice. Mine is a REM STAR PLUS model m if that helps, the blower portion can be detached from the humidifier. If you can live without the humidifier you would not need the expense and power drain of an inverter.
The only problem I ever encountered while camping was when my son turned it up on edge and drained some of the water in the humidifier tank into the blower, it killed the sensor that turns it on when you start breathing into the mask.
/ Lets discuss inverters...... #3
5030, if you can measure the current on the 12 volt side of the inverter two ways. One with nothing plugged in to the inverter and then, number 2, with your cpac plugged in. Your batteries have an ampere hour rating. To start divide the ampere hour rating by the #2 amps and you'll have a theoretical max hour rating. But there is a "but". The ampere hour ratings are based on 20 hour discharge . Example: battery is rated at 60 amp-hr. The battery should put out 60/20 or 3 amps for 20 hours. If the current is higher, the time shortens. Order of magnitude of shortness example: 60 amp-hr might deliver 60 amp for 45 to 50 minutes. And repeated high current discharges consumes the life of the battery and the performance decreases. If you connect your batteries in parallel, you add the amp-hours together to do the above calc. The first current measurement just gives you the overhead or losses of the inverter.
/ Lets discuss inverters...... #4
Will the CPAP need high quality power? The cheaper inverters are "modified sine" wave ... which is essentially a square wave output. Sine inverters are more expensive by a factor of about 3. Their power is a pretty accurate sine reproduction that motors and electronics like better.
Mine is all electronic so I presume it will need clean sine wave power. My genny provides that (Yamaha 2800 Inverter) The camper has 2 large Group 31 deep cycle batteries.
Considering what the machine cost (I own it), I don't want an issue and yes, I can run it without the humidifier, the humidifier unit piggybacks on the main unit.
I have an Li-Ion battery pack for remote hunting trips already but I don't want to use that in the camper and the pack will only run the machine anyway, no humidifier. I can get 2 nights from the pack and then it needs charged, either a 12 volt charge in a truck or 110 in an outlet.
I'm thinking true sine wave. Anyone have any recomendations on a good one?
Also, does it matter where I mount it? I presume they need cooling air but other than that, are there any restrictions? I was thinking under the sink with a hard mounted outlet near the bunk???
I'm figuring if I can get 6 continuous hours on an inverter (before the battery voltage drops too much), that would do it, 6 out of 8 sleeping hours is enough to keep me from being a zoombie....
The humidifier is really not needed, summer camping will be good humidity anyway. I only use my humidifier ar home in the winter anyway.
I know you can buy 12 volt CPAP units just for off the grid but I already own 2, son't need another or the expense (they aren't cheap by any means.
/ Lets discuss inverters...... #6
,,,,,,,,,,,,,,,,,,24 VDC 1500 WATT COTEK POWER INVERTER
I plan to mount one of these on our electric golf cart. Havnt yet so cant recommend it beyond its features and price. ... 24V is usually a premium; and this one is set up to provide 50 or 60 cycle power out. With your 2 batteries you should be able to contrive a series switching arrangement to power it. It will draw less current than a 12V inverter, so you wont need as large wire.
/ Lets discuss inverters...... #7
I too use an ALPHA 3000 Watt inverter for night time use in the event of a power outage. It is transformer based and makes clean sine wave power. I don't like a genset running at night. Mostly because there is no need for it. Remember even deep cylce batteries don't like to be discharged beyond a certain point. I don't remember what is was, but it was not nearly as low I thought possible.
/ Lets discuss inverters...... #8
I have a 12 V cable for mine that came from the manufacturer, as I recall it was about $40. It will plug into a standard 12V accessory plug or clip directly to the battery posts. A deep cycle battery provided at least a weeks worth of 8 hour nights.
/ Lets discuss inverters...... #9
Obviously, if you can avoid making 110V and run on DC that is the way to go.
/ Lets discuss inverters...... #10
This thread has me wondering if my Heat Pump can safely operate off of the power from my 7KW alternator generator, maybe I should dedicate it to that and get an inverter generator for the electronics, lights etc. that share the same circuits.
Then just keep a bucket of ice in the freezer and toss that in the refrigerator when the power goes out to keep the beer cold.
/ Lets discuss inverters...... #11
A compressor could use maybe five times the normal running current on start up, if I am not mistaken.
I'll have to check that out. Not sure mine does have that capability.
One of my hunting buds just built a new home (3 bedroom open floor plan ranch on a crawl) and his heat pimp installer recommended a 17KW, which he just had installed. I have a 17KW myself and it don't run everything, almost, not quite. 7KW ain't much. (7000 watts give or take). The resistance heat elements in your heat pump if they came on, would bury 7KW.
On 240, starting (inrush) amps are 3 times running amps on a capacitor start induction run compressor motor. I have a 7.5 horse in my shop and I've had the clamp on amprobe on it. It pulls pretty hard, almost 28 amps on each leg starting and about 10-12 running, depending on static pressure on the compressor head. The higher the head pressure gets the more amps it pulls.
/ Lets discuss inverters...... #15
I don't have resistance heat, I have to use wood heat when it gets cold.
I have no idea what kind of motor is in the CPAP, I know it has a motor, a small one. I have to presume it's some type of vane compressor, not a reciprocating compressor because the sound it makes is steady. never had it apart.
They seem to last a long time. I still use my original CPAP that I got over 20 years ago, every night. It's an old Resperonics. I think, last time I checked, it had over 28,000 hours on it and still running strong....
Of course it's about 4 rimes as large as my newest one.
/ Lets discuss inverters...... #17
I can almost hear the inverter transistors going "snap, crackle and pop" in cascading fashion as they do.
A generator has the rotor momentum to provide additional motor starting power. An inverter has no such facility unless it is very, very under loaded.
/ Lets discuss inverters...... #18
,,,,,,,,,,,,:confused2:
You have 3 phase power? ... Thats the only way those numbers could be anywhere close to accurate.
/ Lets discuss inverters...... #19
I'm not sure why starting to running current ratio would have anything to do with voltage. A 110V single phase motor could also draw three or whatever times as much current on startup. My 2 HP 110v pressure washer motor draws piles of current on startup and it's hard to find a 15 amp circuit that will run it.
/ Lets discuss inverters...... #20
I have used a single battery with an 750W schumacher inverter for 4 nights in a row and only dropped a 1/2 volt, don't use the humidifier. The CPAP that i take camping is an older backup and is a Rem Star brand.
Dave
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
2019 LGS INDUSTRIES 12 ENCLOSED T/A TRAILER (A60736)
2019 LGS...
2025 GPS Trailer (A56857)
2025 GPS Trailer...
New/Unused Quick Attach Skid Steer Brush Cutter (A61166)
New/Unused Quick...
2011 FORD F-150 (A60736)
2011 FORD F-150...
2001 Ford F-550 Flatbed Truck, VIN # 1FDAF56F61ED50387 (A61165)
2001 Ford F-550...
