L3200/3800/3301/3901 Rear Hydraulic Remotes Install Corrections/Hints
   / L3200/3800/3301/3901 Rear Hydraulic Remotes Install Corrections/Hints #1
s219
Super Member
Virginia USA
Kubota L3200, Deere X380, Kubota RTV-X
I ran into a few errors in the supplied instructions when installing the Kubota rear remote valve kits on my L3200 a couple weeks ago, and thought I should pass on that information in case it would help someone else. Will also be forwarding this thread to Kubota. The instructions are for L3200/3800 models, but I am sure the same kits will be used for the 3301/3901 model updates.
Corrections - Part L7334 1st Position Valve Kit Instructions (for tractor with front loader)
Step 4: cut off more of the mounting tab than shown, otherwise the tab will protrude through the 1st position lever slot on the new lever plate. I cut the tab off halfway through the threaded hole. The hole is no longer used or usable once the kit is installed, so it won't matter. I dabbed some automotive touchup paint on the cut edges afterwards.
Step 8: instructions refer to figure 7, but should instead refer to figure 8. Don't bother tightening the 90-degree o-ring boss fittings to the valve section yet, as you will later need to turn them slightly to get all the hoses to fit together. Due to the braided jacket over the hoses, and the large stainless steel crimp bands for the jacket, the hoses are unable to nest neatly as shown in the illustrations. There is also an interference issue with the detent valves (more on that below).
Step 10: if also installing 2nd or 3rd valves, this is the point where you'd instead use the longer studs supplied with those kits and stack all the valves at the same time (same image above). Because of limited clearance between the rear main case and the fender, the valve stack and studs need to be positioned in place and then the studs can be threaded into the manifold block. I found it helpful to put two temporary nuts on the outer end of the studs, tightened against each other, then use them to help thread the studs into the manifold block. When done, the temporary nuts can be undone and removed, and the permanent washer and nut threaded on. NOTE: I just noticed that instructions for the first valve kit say to torque studs to 11 ft-lbs, whereas instructions for the 2nd position kit (L7364) and float valve kit (L7354) spec 17 ft-lbs. I used 11 since I was following along the first set, but this should be clarified by Kubota and be consistent.
Step 12: connecting the valve manifold block inlet to the power beyond port on the front loader -- there will already be a hose connected to the loader's power beyond, supplying flow to the 3-point hitch. That hose must be removed first, and will need to be used later on.
Step 13: remove 3-point position stops from old lever plate and reinstall on new lever plate -- the original factory-installed lower "knob" stop has captive threads, and cannot be removed from the old lever plate without destroying the knob. A new knob assembly should be included with the kit, or can be ordered separately as part numbers: 04512-60060, 31351-18860, 37410-52610, TC402-36140 (total approx $7).
Step 15: calls for removing/plugging the power beyond port from the valve outlet section unless backhoe or other attachment is present. This port should not be removed/plugged under any circumstances, as it's needed to re-route power beyond flow to the tractor's built-in 3-point hitch even when there is no backhoe or other attachment present. So leave it attached. Take the hose removed in Step 12, and connect one end to the valve outlet power beyond port, and the other end to the hydraulic block under the floorboard (below brake pedals), using the same port the hose was formerly attached to. This process is somewhat illustrated in Figures 22 and 23 under the section "FOR BACKHOE USE", though it's required whether there's a backhoe or not. Step 15 also misses the requirement to install plugs on the end of the outlet sections.
Summary: I believe the errors in steps 12 and 15 came about because the person doing the test fit had access to an L model with backhoe already installed, and made assumptions about that. These steps overlook the basic fact that loader-only tractors route power beyond flow from the loader valve block to the 3-point hitch. When installing the rear remote valves, they are inserted into the power beyond loop after the loader and before the 3-point hitch. Thus, it's critically important to route power beyond flow from the rear remote outlet back to the hydraulic block under the floorboard, where it supplies the three-point hitch. Not doing this step, as the instructions suggest, would disable the 3-point hitch and potentially cause an undesirable/unsafe condition where the power beyond flow got blocked off and was unable to loop back to the reservoir.
Corrections - Part L7354 Float Valve Kit Instructions
Illustrations on page 2 and in figure 3 on page 4 show 90-degree o-ring boss fittings aligned so that hoses run straight back. However, this arrangement will prevent the valve lever from pivoting fully forward into detent, as the rear linkage hits the lower of the two hoses (rearmost hose). The fittings should be turned about 35 degrees to the side, and hoses positioned so that the lever can move freely into detent. This correction applies with any detent valve, whether it's the float valve (L7354) or the standard detent valve (separate part/kit).
   / L3200/3800/3301/3901 Rear Hydraulic Remotes Install Corrections/Hints #2
Do you have a Kubota part number for this kit? Price? I have been waiting for a factory kit to be available. My dealer wanted to install aftermarket but I have seen his install and don't care for it. Do you have any pics of the finished project? thanks
   / L3200/3800/3301/3901 Rear Hydraulic Remotes Install Corrections/Hints #4
Your other thread says you bought from Messicks. For some reason, I typed in a couple of the part numbers and they aren't found. How long ago did you buy your stuff? I wonder whats up with that? I wouldn't mind starting to round up some of this stuff to do my own build.
Great write-up by the way! Your install looks great
You have to buy through the Kubota Wholegoods catalog, which is separate from and unrelated to the parts system. None of this stuff shows up in the parts catalog. You can PM Messicks through TBN or give them a call.
   / L3200/3800/3301/3901 Rear Hydraulic Remotes Install Corrections/Hints #6
Thank you, this is the only good info I've been able to find on this. I'm currently going through the same instruction manual that you had used......
I've managed to make it all the way to installing the last hydraulic line and just want to make sure that I'm understanding this correctly. In order to install my last line I must first remove the existing power beyond line in front of the joystick and install it on the power beyond port on the valve outlet section, leaving the other end of the line in its original location. I then take my new line and hook into the 90 Degree fitting on the process adapter block and the now available power beyond port in front of the joystick? Thanks again
Yes, that is correct. Basically what you are doing is "inserting" the rear remotes in the power beyond loop after the loader and before the 3-pt hitch. Before, the loop went straight from the loader to the 3-pt.
   / L3200/3800/3301/3901 Rear Hydraulic Remotes Install Corrections/Hints #8
Nice, clean installation. By the way, did you ever post what the kit cost? Ballpark numbers are okay, if you are secretive.
I don't remember the number, but I had said $1300 in the other thread back then, so that's probably it. That's for the main kit, one standard valve, and one float/detent valve.
   / L3200/3800/3301/3901 Rear Hydraulic Remotes Install Corrections/Hints #10
Resurrecting an older thread.
I'm getting ready to do this and was wondering if you guys that did it already like S219 have any comments, do or don'ts, and best/only place to order the parts?
I was thinking of adding the third valve at same time. Any recommendations for its configuration?
This is for a 3301/HST.
Current implements
FEL,grapple w/electric Diverter valve, box blade, brush hog and 3pt receiver hitch.
I plan on getting.
Top and tilt
Pallet forks for front and rear
Flail mower
Log splitter
Post hole digger
Prob some more I don't know about yet.
I have experience in hydraulics and will be making or modifying toys to work with the tractor as time goes by.
Thanks
I can't think of anything new to add. But the valves have been working great, no complaints.
Valve type selection really needs to be based on what you plan to run. Get at least one valve with the float detent for your box blade and bush hog.
For a log splitter, you'd want a standard detent valve (so you can lock it open). However, make sure the tractor has enough hydraulic flow for the splitter you want to run before you commit to a 3-point splitter.
The basic double acting valve (which I believe has to be valve #1) is good for cylinders that you want to move in/out without needing a detent or a float.
   / L3200/3800/3301/3901 Rear Hydraulic Remotes Install Corrections/Hints #12
Current implements
I plan on getting.
Top and tilt
Flail mower
Log splitter
Post hole digger
Thanks
Unless you are just dead set on having the integrated valve system, you can get better valves for less money going after market. About a $1000 less. :cool:
   / L3200/3800/3301/3901 Rear Hydraulic Remotes Install Corrections/Hints #13
My install is documented at http://www.tractorbynet.com/forums/hydraulics/295816-kubota-l3200-tnt-3rd-function.html. I love that valve I got from MtnViewRanch.
I'm not quite as happy with my install, especially my disconnects mounting location. They are to close to the 3pt & quick hitch. If I had to do it over I'd mount them higher so it would be less cramped. My first TnT hoses got mangled because of poor design. My 2nd set is better, but still not ideal.
With all the disconnects being so close I have had a hard time keeping those fittings tight. At least one is weeping & its to cramped to get a wrench in there to tighten things & I'm to lazy to pull things apart to pull stuff apart to fix it.
I LOVE float on the toplink & its kind of nice on the side link at times. Get a detented valve if you need constant flow for a splitter or something.
I just got a truck plow ($100 at an auction, in need of a rebuild & fabbing up the SSQA) with hydraulics to replace my current manual one. Debating whether to add a diverter for my lift or curl circuit or just running a hose to the back for my 3rd function.
   / L3200/3800/3301/3901 Rear Hydraulic Remotes Install Corrections/Hints #14
Just as a heads up, I got a few of the low cost electric diverters in, I can get it to your door for $110 if you decide to go that way. :cool:
   / L3200/3800/3301/3901 Rear Hydraulic Remotes Install Corrections/Hints #15
I hear, but have never bother trying to confirm that my dump circuit is regen only. Which wouldn't end up working so well to operate a pair of single action cylinders. Might be hitting you up if I ever figure it out. Going to be a good few months before I get my new blade built, then won't need it until next winter.
   / L3200/3800/3301/3901 Rear Hydraulic Remotes Install Corrections/Hints #16
Just use the lift circuit. Someone on the orange forum supposedly has the problem resolved by using double acting cylinders, not sure how, but that is what they say. :confused:
   / L3200/3800/3301/3901 Rear Hydraulic Remotes Install Corrections/Hints #17
I use a plow with a single double acting cylinder and a grapple with a pair of double acting cylinders with my diverter on a regen dump circuit. It "works".
ac
   / L3200/3800/3301/3901 Rear Hydraulic Remotes Install Corrections/Hints #18
ac
Are you talking about your L45? If so, that valve should have a 4 position curl circuit with the regen being a separate position. Not a problem.
On the economy L models, the regen is the only dump position. It will work on a double acting cylinder, although should be slower one direction vs the other, but not with single acting units typically used on a plow.
Not saying that is how it actually is, but how it seems like it should be. :confused2:
   / L3200/3800/3301/3901 Rear Hydraulic Remotes Install Corrections/Hints #19
I am, and that is not true. The L45 has a regen-only valve. I've posted the hydraulic schematic from the service manual here:
It does work the cylinder pretty slowly in whatever the "dump" direction is. It also winds up having no power up against the stop in that direction. I plan to switch to the lift circuit once the weather is nicer as I can't clamp onto things with the grapple well.
ac
   / L3200/3800/3301/3901 Rear Hydraulic Remotes Install Corrections/Hints #20
ac
I am very surprised that a true TLB has this type of valve. :( Thank you for clearing this up and admitting that on the regen side it is slow and has basically no power. There have been other discussions on other forums where the guys say every thing works fine, same speed, same amount of power etc. I questioned them, but to no avail. It makes no actual difference to me, I don't have those types of valves on anything.
Thanks again. :thumbsup:
Craftsman 42 Inch Riding Mower (A57454)
Craftsman 42 Inch...
2012 DIAMOND C  40FT GOOSENECK TRAILER (A58214)
2012 DIAMOND C...
Adams 5 Ton Spreader (A56438)
Adams 5 Ton...
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A59230)
2015 Freightliner...
2024 CATERPILLAR 305 CR EXCAVATOR (A60429)
2024 CATERPILLAR...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
