Snow plow fabrication
/ Snow plow fabrication #22
How is that not the perfect setup?
I much prefer a pair of sa cylinders as opposed to one da.
Equal forces, equal speeds, and equal volumes of fluid means you can use a simple crossover relief for protection
Excuse my redneck thoughts on this. I look at it as imperfect because there is only one cylinder working against the forces of the blade at one time. For example, if I have the blade angled to the right. The left cylinder is pushing forward on the blade. The right cylinder has no pressure preventing any action other than compression. So if a force pushes rearward on the left end of the blade, the only thing preventing it is the strength of the left cylinder. The right one is just along for the ride. If the left one fails, all the right one has to offer is vacuum???
On the other hand if you have two DA cylinders each, by design, is holding itself in position with hydraulic pressure??
I see this when using my blade. When enough force is applied it acts like it has air in the system. Blade is allowed to move a small amount. Not saying this is a horrible, doomed to failure setup. Just saying it's not as strong as two DA cylinders.
Again, I'm not very hydraulic smart so am open to debate. :)
/ Snow plow fabrication #23
A DA cylinder will offer no more resistance to extension as it will just suck air in through the gland seal.
Only thing a pair of DA cylinders offer is greater angling force if the cylinders are the same size. You gain the pull force of the second cylinder.
And the theory about if one fails....well if that happens you have other things to worry about than a squishy feeling blade.
It is uncommon to see a pair of DA cylinders anyway. Usually it's either a pair of SA or a single DA. The single DA is the inferior setup
/ Snow plow fabrication #24
Good stuff. I think what I was referring to is described in your statement of "You gain the pull force of the second cylinder".
/ Snow plow fabrication #26
My Fisher "V" has 2 d/a cyls. Necessary for independ l/r "wing" movement.
That's the best way to do a vee IMO. But not necessary. Some still use SA cylinders and a spring for return
The type cylinders I have on my old plow truck are SA. I plan to use the same type cylinders on the tractor plow.
/ Snow plow fabrication #29
Also, how would you install a crossover valve on DA system, I believe they would only work on single action pairs.
Mind you even with a crossover valve only the extended corner is protected.
The retracted corner is already retracted so it can not further retract.
The only time that crossover protects is if you are pushing snow away from a curb and hit that curb, usually you are pushing towards the curb.
Still the best blade protection is either a trip edge or optionally a blade that tilts (dumps).
The tilting/dumping blade is the easier to fabricate. (I built my own)
Also the tilting blade can be fine tuned by adjusting spring tension.
/ Snow plow fabrication #30
Crossover is designed to protect the hydraulics, not the blade. So yea, trip springs are still required.
Crossover will work with a PAIR of DA cylinders. Just not a single
/ Snow plow fabrication #31
Won't it work plumbed in between each "end" of a single s/a cyl?
Due to mechanical problems on the old plow truck that are beyond what I care to repair, I've decided use the old plow I have vs. fabricating a new one. This will make things a lot easier and will play into the dissension to go with a hinged plow vs. a solid mount. I've also read some of the other posts and I'm going to figure out a way to support the plow without the chain. I still want to allow the plow to free travel up and down a liitle but I also want the option for down pressure for things like back dragging. I have a couple ideas I'm mulling over, the weight of the plow is what is going to be a factor, its a really heavy bugger.....
My next question is concerning the placement and angle of the SA cylinders, and that is. Is there any reason why I should not have my cylinders angled out were they connect to the mounting plate? on the current design and most all that I have seen where SA cylinders are used shows the cylinders a straight as in this illustration,
What I am considering is shortening the plow arms by about 1 foot, but to do that I would need to move the rear anchor point of the cylinders outward to compensate for the travel distance needed. I know I could just buy shorter cylinders but if a simple change in placement with save me a few bucks... why not.
/ Snow plow fabrication #34
I have a chain that allows a lot of travel, and the plow is still heavy enough for any back dragging too. You might start with the full chain idea first, and then you can have more time to come up with a semi-solid link idea if needed. I know for mine, I am much better off with the full travel provided by the chain than I would be with partial float and solid down pressure.
/ Snow plow fabrication #35
A SA cylinder only has 1 "end"
A crossover will work between a PAIR of SA cylinders that are the same size.
A crossover will work between a PAIR of DA cylinders that are the same size.
A crossover will NOT work between the ports of a single DA cylinder.
When using a pair of DA cylinders, you are using the rod side of cylinder A and cap side of cylinder B for one direction, and the cap side of cylinder A and rod side of cylinder B for the other direction. The volumes are the SAME.
When using a single DA cylinder, you are using the cap side port for one direction and the rod side port for the other direction. The volumes are NOT equal.Thus a crossover valve wont work
/ Snow plow fabrication #36
Yes you can change the mounting but you need to do it the exact same on both sides or it will bind
/ Snow plow fabrication #37
For sure Richard, but there needs to be a little "give" in the system. You're not in that beast of a road grader you run around in:laughing:
True that!!!! :)
/ Snow plow fabrication #38
After one look see at the Deere, To be or not to be isn't the biggest issue I noticed, first thing I'd do is move that plow back 2 ft. so it's not sticking out there a mile, then if down pressure is needed swap the chain out for a piece of round/square stock. Then there shouldn't be any worry's of scratching the car, banging into the house, hitting the garage door, knocking down the clothes line, and tipping over the dog house.
Yes, move the plow as close to the tractors as you can considering the Hydraulics. (Use short cylinders) Leave the pivot wit some slop, and reinforce heavily the skid steer plate you are using to stiffen it up. it takes a beating.
Mine is welded solid. I use on gravel roads, but I hate plowing our neighbor's crappy excuse for a rad up to their riding arena. A decent gravel driveway is no problem once it freezes.
/ Snow plow fabrication #39
My driveway was nice and smooth with two snow storms, now with the past couple warm days, it's all rough again, rocks sticking up.... This weekend before the next big blizzard, I'll try to fabricate something for plow shoes to keep the blade up, this banging banging and tripping the edge all the time takes the fun out of plowing snow. Anyone else make shoes for a plow, or does everybody have a hot top driveway.
/ Snow plow fabrication #40
I had some shoes made for the Curtis plow on my RTV. The ones that came with it were ridiculously small and sank into the driveway. The guys at work made them out of 1" plate. Probably 5" round and they put a nice 45* chamfer around the edge.
For a full size plow I would probably go with a 6" dia. If your not inclined to make them Tractor Supply has them for $20 a piece.
2014 Ford F-150 4x4 Ext Cab Pickup Truck (A64194)
2014 Ford F-150...
Caterpillar C18 Industrial Diesel Engine - Serial N8F01121 - Power Unit - Pump Takeout (A63689)
Caterpillar C18...
2022 MORBARK EAGER BEEVER 1215 WOOD CHIPPER (A63276)
2022 MORBARK EAGER...
2009 VOLVO VNM 300 6X4  T/A DAY CAB TRUCK TRACTOR (A59906)
2009 VOLVO VNM 300...
Caterpillar 963C/953C Track Loader Service Manuals (A63117)
Caterpillar...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
