Filter Help XR4040
/ Filter Help XR4040 #1
skidsareforkids
Gatesville, TX
LS XR4040
I'm getting ready to do my 50hr service and need some filter cross reference help
Oil--------------Wix 57000
Hyd-------------Wix 51715
Fuel Pre-Filter----???????
Can anybody confirm those two numbers and provide me the third?
/ Filter Help XR4040 #2
I have the xr4046 which should be the same engine as yours I think. After much research I found oil should be Wix 51056, Hyd- Wix 51715, and fuel pre filter- Wix 33003. I have not changed mine yet so I cannot say for sure this is right but if you search on here you should find the info you need.
/ Filter Help XR4040 #3
I use NAPA filters but you can cross reference them to other brands.
Oil filter: I use NAPA 1348. It has the same specs as the NAPA 1056 but is slightly longer. Either one will work.
Hyd. filter (main): NAPA 1715
Hyd. filter (HST): NAPA 1551
Fuel pre filter: NAPA 3003
Air filter (inner) NAPA 6490
Air filter (outer) NAPA 6489
/ Filter Help XR4040 #4
Just for reference, when I did the service on my LS, it was cheaper to buy the filters from them than to buy aftermarket. There has also been a lot of confusion on part numbers for LS tractors in the past year or two, and it doesn't seem to have cleared up.
/ Filter Help XR4040 #5
With how picky companies are getting with warranty clams is it really worth going with after market ?
/ Filter Help XR4040 #6
Your warranty cannot be denied due to after market parts. Magnuson-Moss Warranty Act.
/ Filter Help XR4040 #7
That is true if the after market filter is of the right spec's for use in the tractor. After looking in a book cross referencing 4 or 5 filters and going cross eyed and the part man picks a sixth one the wrong one then you will have to plea with the tractor maker. I go once a year to see my dealer get to talk to him get my filters. If I didn't I would never see him.
/ Filter Help XR4040 #8
Guess I should have elaborated a bit more on what I was getting at , and that's if the wrong filter was used or one that didn't quite match factory specs, OP was unsure of the filter number and if by chance got the incorrect one , could cause a lot of hassle with warranty claims if a problem were to arise.
Thanks guys I'm just going to use the factory filters. I just can't find enough info about the factory filters to make sure I'm getting a true replacement. Lots of filters out there will fit but when you start looking at flow rate and filtration I can't make an educated decision without knowing the specs of the factory items.
/ Filter Help XR4040 #10
I use napa (wix) filters , they have a listing for most of the filters for my tractor , I generally will cut and inspect oil filters after servicing , the napa filters have a much better construction compared the OEM from dealer ...just my thoughts
/ Filter Help XR4040 #11
Both Wix and Napa have a cross-reference for most LS tractor Filters ,no warranty issues , some are a bit cheaper some are higher priced than OEM , however the Napa/Wix filters are much better quality than Factory..... , I don't have a local Napa , I buy mine from O'rallys wix makes the Napa filters they use the same cross reference, napa drops the 5 (wix oil filter = 57000 Napa oil filter = 7000)
I found plenty of filters that would fit. What I couldn't find was the specs of the LS filters so that I could compare flow rate and filtration. I want to make sure that not only is the filter going to fit but it is going to perform in those two areas the same as the LS filters.
/ Filter Help XR4040 #13
Wix filters don't just fit they are listed specifically for LS tractors ,no warranty issues.. .. i have opened the LS filters they look a lot like Fram motorcycle filter on the inside , Wix is.a.much better check it out for yourself
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2020 JOHN DEERE 770G MOTORGRADER (A63276)
2020 JOHN DEERE...
2020 INTERNATIONAL LT625 SLEEPER (A59911)
2020 INTERNATIONAL...
2012 Ford E-350 Passenger Van (A61573)
2012 Ford E-350...
Lot of 4 12-16.5NHS Skid Steer Wheels and Tires (A61572)
Lot of 4...
2023 Case TV450B (A62177)
2023 Case TV450B...
