Snow 59" Front Mount Blower on 755
/ 59" Front Mount Blower on 755 #1
Kevin M
Gold Member
goshen NY
48" bobcat walk behind , 60" Dixie Chopper Classic , 755 John Deere 4x4 70 ldr belly mower etc etc , 7610 Ford 4x4 7412 ldr and 10 ft rhino hogg
Was wondering if you guys would recommend this is anyone else running one on a 755 ?
/ 59" Front Mount Blower on 755 #2
I think it would be a fun project and look really cool in the Labor Day parade. But for blowing snow with it, I don't think your tactor is heavy enough to handle it and the 15 pto hp isn't nearly enough power. If you have the supplies to make your own mounts, carrier bearings and drive shaft, do it and show us some pictures.
/ 59" Front Mount Blower on 755 #4
They also made the same style in a 47" size. My caution would be the 755 is a bit aged by now,
and probably not making the power it did when it was new,, that 59 would be a lot of blower
in deep snows for that tractor, IMHO.
do you have a chance to buy a used one?
Yeah I have a chance to buy a used setup that apparently came off a 755 ,
, The 59" did come on a 855 which is like 2hp different otherwise the same tractor with a slightly longer frame
/ 59" Front Mount Blower on 755 #7
Wow, proved wrong again! I had no idea a tractor as small as a 655 with 10.5 pto hp could be matched up with a 59" blower.
I think that's was just for the hitch attachment part
I'd probably be better off with the 48" if I could find one locally
