2615 coolant leak
/ 2615 coolant leak #1
rterry
Chattanooga, TN
2615 Mahindra
The coolant drain tube that runs along the bottom of the frame from the radiator to the block that has the drain cock inline pulled loose from where it connects to the engine. And now I can't find where it connects back. Somewhere on the back of the block and not much room to work. Any suggestions?
Mahindra 2615 4x4 that is 7 or 8 years old.
/ 2615 coolant leak #2
Were at the radiator does it come from
/ 2615 coolant leak #3
Do you see a small bowl with a drain on the bottom of it? theres one line that goes to it and sits on the side of the block if im thinking right
/ 2615 coolant leak #4
then the top one goes to the reservoir then the big one goes to the water pump..
/ 2615 coolant leak
The line comes from the bottom right side of the radiator. I did not see a bowl with a drain. When I add water it runs out somewhere behind the engine and the line is long enough and originally went in that direction. I just see no way to get in there.
thanks
/ 2615 coolant leak #6
thanks
I went out and looked at my 2615 to see if I could tell where the hose is connected. Yikes! It looks like there is no access to the back of the engine without pulling it out of the chassis.
/ 2615 coolant leak
Hey I appreciate you going out and taking a look. I was afraid of that. I guess that explains when I called the dealer he just said "umm it may be a little hard for you to get to. Why don't you just bring it in."
You may want to attach yours really good to the frame to avoid the same problem.
/ 2615 coolant leak #8
I will double check to make sure it's secure. Please let me know the outcome on this. It may help several other owners in the future.
/ 2615 coolant leak #9
can you take off the dash to get to it?
1016 (A61166)
1016 (A61166)
2013 Chevrolet Silverado 1500 4x4 Ext. Cab Pickup Truck (A60352)
2013 Chevrolet...
2019 Mitsubishi Mirage G4 Sedan (A61569)
2019 Mitsubishi...
Electric Concrete Mixer (A61166)
Electric Concrete...
Greenworks Commercial 82V Utility Vehicle 500 CAMO Model: U500SC - DEMO UNIT (A63118)
Greenworks...
17394SFL (A61568)
17394SFL (A61568)
