need help adjusting relief pressure at spool
/ need help adjusting relief pressure at spool #1
memphismark
california
Bobcat
Hey guys. Was wondering how to adjust the pressure relief in a Prince 20 gallon open center spool. It's factory set at 1500. Would like to bump it up to 2200-2500 for more torque. Do I need a pressure gauge teed into the line? I'm guessing the line needs to be pressurized? Would appreciate some help.
memphismark
/ need help adjusting relief pressure at spool #2
What are you supplying it with (GPM) and what is the relief valve on the supply set at?
Yes you need a gauge...tee it into one of the working ports and max out or in whatever cylinder etc, it is attached to...see what the gauge says...move the lug (usually CW to increase the pressure, CCW to decrease) on the PRV until the gauge reads what you want (in accordance with the PRV on the source)...
/ need help adjusting relief pressure at spool #3
memphismark
Install a 3000 psi hyd gauge in a tee and install it in the IN port of the valve in question.
If the relief valve uses shims, install the shim pkg. Engine off.
Use the valve lever to fully extend the cyl, or retract and read the pressure.
With engine running, and the relief valve is adjustable, monitor the gauge, and turn screw in to increase pressure and out to reduce pressure.
relief is set to 1500 at factory, for about 14 GPM on a concrete mixer. My problem is the only way to put a load on system is to mix concrete. That makes me nervous because clock is ticking with concrete if you know what I mean. Can I just plug the line to 'put a load' on system and then proceed with adjusting? I'm a hydraulics novice so thanks for your response.
/ need help adjusting relief pressure at spool #5
Yes, but only momentary.
Momentary because it could damage something? memphismark
/ need help adjusting relief pressure at spool #7
Not gonna damage anything because thats what the relief is for.
1988 Ford Mustang GT Convertible (A61574)
1988 Ford Mustang...
2015 HYUNDAI HX220L EXCAVATOR (A64279)
2015 HYUNDAI...
2025 48in Drum Mulcher Skid Steer Attachment (A61572)
2025 48in Drum...
CARRYALL 1700 UTV (A64280)
CARRYALL 1700 UTV...
1143 (A63745)
1143 (A63745)
2025 JMR 4x8 Forklift Safety Basket (A61572)
2025 JMR 4x8...
