Cost to Survey 80 Acres
   / Cost to Survey 80 Acres #1
EdwardB
Michigan
JD 4410
I am looking at an 80 acre parcel (two square 40's) to purchase. I was quoted $1,650 to survey the property. Scope of work:
Tie into the necessary section corners in order to calculate the boundary.
Set ス iron rods with my survey caps or verify existing irons at the boundary corners.
Raise the boundary corners with 4 foot wooden lath and flagging.
Mark the west boundary line with 4 foot wooden lath and flagging spacing approximately every 100-200 feet (I will make sure they are intervisible).
Place a few 4 foot wooden lath with flagging along the north and east boundary lines.
Provide you a certified survey showing the results of the survey.
I have attached a photo. This seems quite reasonable to me. Thoughts?
   / Cost to Survey 80 Acres #2
That sounds reasonable. Out this way I would expect it to be north of $2500.00... If you think about it, many of the local engineers have at one point or another surveyed land multiple times, for different owners. All of this is stored on a hard drive somewhere and they still charge full freight to the next guy who is in line.
   / Cost to Survey 80 Acres #3
Would cost 3X that, minimum, here. I was quoted $3K to survey 5 acres by a guy who had field notes on 3 of 4 sides of my lot from 5 years prior.
   / Cost to Survey 80 Acres #4
The cost depends on when the last survey was done and difficulty of access.
Here I was quoted $1,100 for a survey due to the nearest last survey was 1/2 mile away.
Your quote does not seem that far out of line.
   / Cost to Survey 80 Acres #5
Cost varies greatly by zipcode. see my post above.
   / Cost to Survey 80 Acres #6
I paid $1000.00 for 10 acres and it had the corners marked. At least I have the peace of mind to know they were accurate. A neighbor of mine (#1) bought his house and found out it was built over the property line. Good thing the other neighbor (#2) was willing to swap an acre so his house (#1) is now on his own property. :thumbsup:
   / Cost to Survey 80 Acres #7
I paid 5k to do 15.5 acres here in NE Ohio. Corners pegged and markers every 150 feet.
   / Cost to Survey 80 Acres #8
I'm just a slacker Missourian. Why would the buyer pay for a survey if it's in question???
   / Cost to Survey 80 Acres #9
A surveyor told me acres didn't matter. It would cost $900 per point (corner, etc) that was marked.
Bruce
   / Cost to Survey 80 Acres #10
Depends on where the property and the local laws. In Texas your property is either part of an legally incorporated area (such as sub-division or in a city limits) or in an unincorporated zone (i.e. rural area). If you are in an unincorporated area, you have to have a boundary survey for a transfer of title.
2023 PJ 49FT Gooseneck Trailer - 35+5, Mega Ramps, 30,000 GVW, Electric Brakes (A52128)
2023 PJ 49FT...
Aluma 7712H Tilt Trailer (A50514)
Aluma 7712H Tilt...
Ford 1320 Tractor (A50514)
Ford 1320 Tractor...
New Holland 451 Sickle Bar Mower (A50515)
New Holland 451...
(4) Stand Alone Texas Panels (A50515)
(4) Stand Alone...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A52128)
2018 John Deere...
