Good morning!!!!
   / Good morning!!!! #41,381
Good morning! 35˚ clear skies. I just threw the last two logs in the wood burning stove - the inside temp is 71˚. I only start the fire on days in the 30s and I have already depleated the pile - out to the woods to find a dead tree that is about a year dead. I can just about tell the length of death by weight of the wood - No autopsy needed.
Autopsy, that reminds me, its dry enough for a tractor road trip to bury my Mom's cow that died last week (old age), it has been cold enough maybe it does not stink, NOT.
Our VFD voted to buy 3 new air packs so I get to go shopping, any suggestions from anyone who has bought one recently?
Instead of building more buildings I'm downsizing. My nephew said he will pass on buying the 1947 Farmall so I need to start ordering a tie rod. It has to be in good working order before I sell it to the general public. Any one know a good price to ask?
   / Good morning!!!! #41,382
Don, it's been a long time since I lugged one of these around, and I think way back when we only got half an hour on a bottle
but Scott was to airpacks like Kleenex was to bathroom tissue. And once you start stocking parts, you kind of get in bed with one manufacturer
or another. I bet these things cost a couple grand a piece. Cheap if you save someone's life...
I wonder if Amazon sells them...:rolleyes:
   / Good morning!!!! #41,383
Good Morning! 45F @ 7:00 AM. Sun and clouds mixed. High 58F. Winds SSE at 5 to 10 mph.
Another front comes through tonight dropping as much as an inch, then a series of storms are due in over the next week or so bring another 4". Fingers crossed...
Emptied the wood stove first thing this morning so I wouldn't have to do it in the rain tomorrow. That should last four or five days if I remember to open all the dampers before I hit the sack so all the embers will turn to ash. Started into the second cord of wood for the year last week, so I'm burning a little more than last year but nothing like you folks in really cold country.
Need to take a look inside the rain gauge today. The little guard I made to keep the birds off came loose, and the intake got loaded up with poop. I think some got down inside, as it filled up with water in last week's storm causing very erratic readings.
Have a good one, folks!
   / Good morning!!!! #41,384
Good morning all. 29F this morning and sunny, calm winds. Forecast for 60F light winds and sunny until Saturday. Finished up a couple of hours consulting last night and this morning, Costco run this morning, and split firewood on TMA.
   / Good morning!!!! #41,385
Good morning, woke up to 2 1/2" of snow and a temperature of 27F, dropping to 19F this afternoon.
Hope that all who are ailing are feeling better.
   / Good morning!!!!
17 here, not getting much higher. Going to lunch with friends, then back home to plow out paths for me and the dogs to exercise on. Then to reorganize the closet, I have some old clothes to take to the SA. Other than that, not much. Have a good day, guys!
   / Good morning!!!! #41,387
23.9F with a bit of light snow occasionally ... cold front just passed through about an hour ago, temp has dropped about 6F since 09:00 ... low tonight is predicted to be 7F.
Just finished up making some food for the hypostomus plecostomus: cut a 1 1/2" x 1" piece of stem off some broccoli and chopped it up in around 1/8" pieces and then blanched in in boiling water for 60 seconds. Stuck it in the freezer to cool it off for a few minutes and then dropped a couple of pieces into the tank.
He's already been out to investigate (usually don't see him much during the day) and is sitting out near the front of the 10g, next to what's left, kinda like he might be guarding it. The danios and plattys managed to pick at it on it's way down to the bottom. I have one medium-sized, fully-cooked shrimp thawing as well, which I suspect will be welcomed :D
Tested the filled 55g for ammonia this morning and it's already reading around 0.50 to 0.25 ppm (down from 3 to 4 ppm) ... so it looks like the bacteria off to a good start. Will retest tomorrow morning and if it's down to zero I'll dose it with ammonia again to take it back up to 2 - 3 ppm and see how long it takes it to drop to zero.
Have to run down to the hardware store and pick up an o-ring for the union on the other RUGF, as well as a second petcock for an air bleed on the hard pipe and some tubing for siphoning the tanks. Should be able to get the other filter hooked up later today.
Also need to check out a stand for the other 55g that I found on craigs ...
Have a good day all ...
   / Good morning!!!! #41,388
RS, fish pictures! How about a Platty driving a little tractor?
Good trip downtown, TSC had just the culvert pipe I needed, a 20 foot double wall 12 incher.
Need to hook up the trailer and go back and get it. Always fun to walk the equipment lot at TSC though my local one is very small.
   / Good morning!!!! #41,389
Farmer, how many times do you change out birds a year? How are your cows doing?
We raise about 6 flocks a year. Depends on the calendar sometimes it's only 5.
Cows are doing good. Eating hay and any new growth of the wheat. How's your cattle?
   / Good morning!!!! #41,390
66°F and .27 inches rain last 24 hours
Be safe
Have a great day
David Sent from my iPad Air using TractorByNet
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
2024 John Deere 331G Skid Steer w/ WARRANTY! LOW HOURS (A59213)
2024 John Deere...
2017 FORD F-550 SERVICE TRUCK (A58214)
2017 FORD F-550...
2008 MOTIV ALUMINUM TRAILER CO. 32 TRI AXLE GOOSENECK ENCLOSED TRAILER (A58214)
2008 MOTIV...
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
CAT D6T LGP DOZER (A58214)
CAT D6T LGP DOZER...
