Changing tire size on a four wheel drive tractor
   / Changing tire size on a four wheel drive tractor #21
1200 is probably a bit light. My smaller l3400 loader and framework is 950# bare. Bucket adds 260#. So I'm at 1200# total.
I would assume the l5740 would be closer to 1200# for just the frame, if not a bit more. Add a ssqa and forks...
   / Changing tire size on a four wheel drive tractor #22
My LA724 loader weighs 1,100 without the bucket.
   / Changing tire size on a four wheel drive tractor #23
Right... And we compared the 754 & 854 and they are nearly the same. Slightly bigger cylinders. So ultimately right around 1200 lbs.
   / Changing tire size on a four wheel drive tractor #24
He is right at 1500 pounds with the bucket attached.
2024 CATERPILLAR 299D3 SKID STEER (A52706)
2024 CATERPILLAR...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
UNUSED WOLVERINE PFF1-13-45W PALLET FORK FRAME (A54757)
UNUSED WOLVERINE...
2008 Komatsu WB146-5 (A47477)
2008 Komatsu...
New Kivel 3500 lb. Skidloader Forks (A50775)
New Kivel 3500 lb...
Two Post Car Lift (A50120)
Two Post Car Lift...
