Converted a Western Snowplow to SSQA.
   / Converted a Western Snowplow to SSQA. #21
Thanks George. Yes I will go with that one. Kenny also said to go for the higher psi unit.
   / Converted a Western Snowplow to SSQA. #23
I bought the one from kenny. He shamelessly, in my opinion, doesn't push them on anyone and I greatly respect that. Kenny's valve is very nice, no, excellent. You can talk to him as well if a problem arises. It's a few more bucks but it was worth it to me!
Ditto, your braces are going to interfere with the QA plate., you are going to have to cut them off and move them unless there are reliefs in the tractors mounting hardware?
Well, you guys who said there would be interference were right. Although the plow set up work ok on my soninlaw's LS, it didn't fit the ssqa I put on my Kubota. The fel arms are spaced more narrowly on my Kubota B2620, so there is interference with mine. I'm going to modify the plow set up. Probably put a junk of 2" by 1/2" flat steel bar about 8" long on the bottom of the plate and then weld it to the 2" tube and cut out a section of the tube.
I'll post back when I get it reworked.
In the meantime, please check out my SSQA build thread. http://www.tractorbynet.com/forums/customization/349748-another-pin-ssqa-conversion.html
   / Converted a Western Snowplow to SSQA. #26
Hey its no big deal. That's all part of the fun figuring out how to make stuff work. I wish I could say my projects always went smoothly but they almost never do. If something is going smoothly I start getting worried because something is going to go wrong soon. :thumbsup:
Working on it. Cut the 2x2 tube back. Welded in a 2" x 5/8" bar under the the plate and bridged to the 2x2. Got one done. I'll weld up the other side tomorrow.
It was a royal pain tho cut that darn tube off. uploadfromtaptalk1452031145650.jpg
Ok. I got the other side done and hooked it up to my new quick attach on my Kubota B2620.
I have to paint the revised area but I'm going to declare victory on this.
Forgot the pics uploadfromtaptalk1452109782830.jpguploadfromtaptalk1452109789312.jpg
   / Converted a Western Snowplow to SSQA. #30
Ok., thanks George. That came out nice. I just talked to my son in law. He's not that interested in paint right now. He's paying for the parts and I'm doing the labor. But I know paint isn't much. I may just do it for him.
Conventional air dry (rattle can) paint will have issues sticking to a powder coat base because the powder coat is heat cured (imagine a low temperature ceramic overcoat). You need to really scuff it and or remove it by media blasting.
1268 (A50490)
1268 (A50490)
BUYERS PREMIUM & PAYMENT TERMS (A51222)
BUYERS PREMIUM &...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A52128)
2016 KBH...
2013 Dodge Journey SUV (A50324)
2013 Dodge Journey...
2017 Chevrolet Express 2500 Cargo Van (A50323)
2017 Chevrolet...
2015 Mitsubishi Mirage Sedan (A50324)
2015 Mitsubishi...
