New vineyard tractor
/ New vineyard tractor #1
mowine
Missouri
Kioti CK20HST
After 4 years of doing everything by hand in my 3 acre vineyard I broke down and bought a CK20hst with FEL. While I'm getting the parts together to build my sprayer I went ahead and put about 8 hours on it bush hogging the neglected fields on the rest of my property. The picture is a hill top I am getting ready to plant next year. I wanted a small tractor that could get up in down the vineyard rows and still have enough weight and power to handle a 55 gallon pto sprayer and bush hog. So far everything is working great.
/ New vineyard tractor #2
Congratulations! That is a nice view atop that hill. /forums/images/graemlins/cool.gif Is that a 60" rotary cutter? How did the CK20 handle that thick stuff?
Thanks
The rotary cutter is a 52" midwest brand. It seems well built. It works well with this tractor. I took down some fairly large saplings 2" diameter without any trouble. When I got into some honey suckle I had to slow down some or it would begin to bog down. Next I need to practice with a post hole digger.
/ New vineyard tractor #4
</font><font color="blue" class="small">( Next I need to practice with a post hole digger.)</font>
That was my first attachment. Piece of cake to use. Run about 1,500 RPM's and turn down your 3pth "raise" speed to slow at first. Once you get the feel of it, you can adjust accordingly. G
/ New vineyard tractor #5
Hey congrats mowine! I sure like the looks of that tractor and the cutter looks to be Kioti Gray. Of course, I should like the looks of yours since I have the same kind. /forums/images/graemlins/grin.gif
Amazing little machine isn't it? People are always surprised at how much it can do.
That sure is a beautiful setting for that CK. Enjoy and give us more action pics, okay? Thanks, John
<font color="blue"> turn down your 3pth "raise" speed to slow at first </font>
Thanks GerardC
I was having some problems with the digger getting away from me. I used your suggestion and with a little practice I think I got it. I have a 12" auger. I am using mainly to drilll holes to plant grape vines. I have about 3 hundred to plant next year. Plus the trellis posts.. Should be a pro after that.
I got the pto sprayer working this morning. Too windy to do any real spraying today, but calibrated the nozels with water and am ready to go. I will attach a couple more pics.
another vineyard pic
last one
/ New vineyard tractor #11
The view on your property is very nice! The tractor looks good, too! /forums/images/graemlins/wink.gif /forums/images/graemlins/cool.gif
/ New vineyard tractor #13
Really nice setup mowine. That's a beautiful vineyard. The only thing I see you don't have that I think you would really use is a toothbar for that loader. For under $300 it makes a great deal of difference in loading piles of trash and other stuff, and makes digging small brush/trees so much easier. Bolted in with two bolts in the end of the loader, it's very easy to put on and remove. Let me know if you want information on getting one. John
/ New vineyard tractor #14
Ran across this post. Are you still growing grapes. I'm interested in Missouri grape industry and am looking to discuss the topic with someone knowledgeable on small vineyards. Thanks
/ New vineyard tractor #15
Awesome. Looks like you have a little piece of heaven there. :)
/ New vineyard tractor #16
Ran across this post. Are you still growing grapes...
farmerwanttobe, This post is several years old and the OP (original poster) hasn't been around since 2009.
mowine, Last Activity: 04-27-2009 11:18 AM
There is a slight chance if you send him a PM (private message) it will be copied to his e-mail address (that is if he still has the same one). Worth a shot... Just click on his name and a menu will open, the second selection will be private message.
/ New vineyard tractor #17
Very nice rig. I'm interested in how good the canopy penetration is with your pto pump sprayer. I built my sprayer with electric pump and after a year added air blast to get better penetration. What I gave up, however, is the ability to spray both sides of the isle at once. I have to go down each isle twice. Not a problem since I have a very small vineyard. It does give my very good canopy penetration.
/ New vineyard tractor #19
If you start a new thread of your own requesting help......there are a number of experienced grape growers that will help you
2015 KOMATSU PC170LC-10 EXCAVATOR (A62129)
2015 KOMATSU...
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
2018 Bobcat S-570 (A63689)
2018 Bobcat S-570...
2011 Terra Riser 300D-SA Fire Plow Attachment (A61572)
2011 Terra Riser...
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A63689)
2023 Kubota Z412KW...
KUBOTA KX033-4 EXCAVATOR (A64279)
KUBOTA KX033-4...
