Pouring Hydro oil from pail.
   / Pouring Hydro oil from pail. #21
I sit the bucket on the seat and siphon the oil in through the dipstick hole with a length of 3/8" clear plastic tubing :| it's pretty slow so I leave it siphoning overnight, by the next morning it's all in there.
   / Pouring Hydro oil from pail. #22
Those pumps are worthless unless you have a whole day to spend pumping it. The HF model pumps 2 ounces per stroke. That's 410 strokes per 5-gallon pail. My last change took almost THREE pails. That works out to 1,230 strokes. Just the thought makes my elbow ache. I prefer to just muscle them up like I do with the 5-gallon gas or diesel cans.
   / Pouring Hydro oil from pail. #23
I bought a GPI Pail pump at TCS for $35.46 (tax included). I used it to refill my Kioti CK30 HST with ~ 8 gallons of Super UDT-2. I took me ~ 10 minutes of actual pumping. This pump transfers fluid in both stroke directions, however it delivers more fluid during the up stroke. Pumping was effortless. The only complaint I have is with the provided plastic clamp used to secure the pump to the pail's spout. I could not tighten it. I had to drive to the nearest True Value store and buy a metal worm band hose clamp. Of couse I could have lugged the pail over my shoulder and poured directly in the funnel. But doing so I could have risked spilling some fluid on the tractor and my garage floor. Instead I moved a 55-Gal empty drum against the back of the tractor, placed the 5-Gal pail fitted with the pump on the top of the drum.
   / Pouring Hydro oil from pail. #24
Yeah, that one is a little better at one cup per pump. :cool:
   / Pouring Hydro oil from pail. #26
As long as the funnel doesn't have a filter screen it works pretty good. It works better if you have a helper to hold the funnel. The filter screens don't work good on oil and take forever to pour anything. The oil fill port is pretty big. If you can get a funnel with about a 3/4 inch opening it goes pretty fast. Long before you find a pump and then slowly pump the oil and finally clean up up the pump I will be finished and back to work.
   / Pouring Hydro oil from pail. #27
I needed six gallons, so I bought a 5gal and a two gal. Used the 2 gal 1st, then refilled it from 5gal resting on a milk crate so I didn't have to hold it up and poured that it. Holding 35 lbs steady while pouring into a funnel looked like a recipe for an oil spill.
   / Pouring Hydro oil from pail. #28
As a society we used to haul 100 lb sacks of feed, 80 lb sacks of fertilizer, Cement and mortar mix and think nothing of it. I wouldn't think anything of slinging a sack of feed on my shoulder, or loading 2 tons of bagged fertilizer on the pickup every other day for three weeks, and unload it into the corn planter. Now we look for crutches to help with 35 lb pails.
Yes, boys & girls, I am including myself in this commentary, although I still can pour oil from a 5 gallon pail (for now).
Throwing a 80lb sack on your shoulder puts all the weight on your skeleton. Duck soup. Holding a 35lb weight out two feet from your body requires a lot more muscle energy. Try holding a one pound can of soup at arms length and see how long you can keep it level with your eye with your arm straight.
   / Pouring Hydro oil from pail. #29
Thanks for the physics lesson, but I've been handling this stuff all my life. If you can't figure out how to pour a 5 gallon pail from closer to your body than 2 feet, buy a pump.
   / Pouring Hydro oil from pail. #30
How do you get closer than 2 ft to a HST oil spout that is buried in front of the 3PT arms and almost on top of the rear axle? Many tractors are set up like mine. My solution has been to decant the oil into a two gallon container but a 5 gallon pail pumping efficient, would be an alternative.
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2014 MACK PINNACLE (A55745)
2014 MACK PINNACLE...
2012 Chevrolet Van (A55973)
2012 Chevrolet Van...
2016 INTERNATIONAL PRO STAR TANDEM AXLE DAY CAB (A58017)
2016 INTERNATIONAL...
2013 Ford F-750 Pak-Mor 16 CuYd Rear Loader Garbage Truck (A56858)
2013 Ford F-750...
500BBL FRAC TANK (A58214)
500BBL FRAC TANK...
